01-22-2015, 06:31 PM
#11 (permalink)
Originally Posted by spacemanspif
Neat idea Eddie! After seeing Metro's bumper ones I've been thinking of doing the same to my curved bumper but couldn't really think of a easy way to do it, I'll have to give the folder clips consideration.
Forget the easy way, let's do it the HARD way!
Btw...my version is unfinished, so i dont know if it will help or hurt mpg. I just wanted to find something to do with the leftover fiberglass/bondo i had lying around
The Following 2 Users Say Thank You to jedi_sol For This Useful Post:
01-22-2015, 07:52 PM
#12 (permalink)
Spaced out...
I like it for a prototype, Jedi, but after all the bright blue tape on my Saturn, the GF is kind of "over" riding in a car covered in tape. I have thought about cutting a slot in the bumper where a strip of coroplast can just be inserted and basically press fit in. Of course, tape on the inside of the bumper would ensure it stayed in properly.
-Mike
2007 Ford Focus ZX5 - 91k - SGII, pending upper and lower grill bocks - auto trans
1987 Monte Carlo SS - 5.3/4L80E swap - 13.67 @ 106
2007 Ford Focus Estate - 230k - 33mpg - Retired 4/2018
1995 Saturn SL2 - 256K miles - 44mpg - Retired 9/2014
Cost to Operate Spreadsheet for "The New Focus"
The Following User Says Thank You to spacemanspif For This Useful Post:
01-22-2015, 09:34 PM
#13 (permalink)
The e-Golf has something similar:
Here it is on the right, compared to the standard Golf:
01-22-2015, 11:40 PM
#14 (permalink)
herp derp Apprentice
Floor cord covers
I was thinking these, but cut in half, stuck on w/ 3m molding tape. Looking around a bit I saw some as thick as 15/16". Don't know how well they would stand up to sun and weather though
The Following 2 Users Say Thank You to 2000mc For This Useful Post:
01-23-2015, 01:35 AM
#15 (permalink)
Fiesta - '06 Ford Fiesta 1.4 Ambiante 90 day: 45.9 mpg (US) Dakar - '03 BMW f650 GS Dakar (retired) Tucson - '07 Hyundai Tucson 2.0 GLS 90 day: 32.67 mpg (US)
noted with this car is the small antenna on the arial. im looking at that too instead of completely deleting mine. wonder how much a set of those rims would be looks good for earo rims!
#16 (permalink)
Dam that looks good from the back!
The Following User Says Thank You to Eddie25 For This Useful Post:
01-23-2015, 01:43 AM
#17 (permalink)
Originally Posted by 2000mc
Floor cord covers
my plan is also to use moulding tape or i think here we call it double sided tape. small slits in those clips will make it bend somewhat over curved areas. i am trying to find bigger clips these are only for A4 paper but i have seen A1 drawings clipped together. they were about twice the size than these.
also they are plastic and easy to modify u can easily cut one in half if you need less of a 'ramp' effect. best part is they cost 11 cents each converted to your currency!
01-24-2015, 02:26 PM
#18 (permalink)
flap
addSome 'angles' at the back of cars can produce what Hucho calls 'bi-stable flow',where the separation line will dance around.
A 'flap' can trigger positive separation (Chrysler calls it 'burst'),fixing a constant coefficient of drag.
I suspect that during development work within the new aero-acoustic wind tunnels,that they were picking up cyclic 'booming' behind the original stylists design,and the flap is a cheap fix for bad aerodynamic design.
Kamm/Fachsenfeld studied these flaps in the late 1930s.
What's old is new again!
Here is the 1930s 'flap'
Reason: add image
The Following 6 Users Say Thank You to aerohead For This Useful Post:
01-26-2015, 03:11 AM
#19 (permalink)
I wonder if that wil be a good idea to see just how much these 'flaps' will work? to do just one side of a car and see if you can pic up any difference in the cars handling or if it is pulling to a side?
01-26-2015, 06:23 AM
#20 (permalink)
Spaced out...
Probably not enough to notice handling differences but tuft testing might show a difference and you might possibly notice more dirt collecting on the side with the treatment due to less air turbulence not blowing dirt off.
-Mike
