Old 06-09-2014, 04:55 PM   #1 (permalink)
90 day: 51.82 mpg (US)
2014 Mirage aeromods A-B test: grille block, mini-Kammback, air dam, mirrors, 1 wiper
To get ready for the 2014 SMCC Economy Run event in Montreal, I put together some coroplast mods for the 2014 Mitsubishi Mirage 5-speed I borrowed.
(See also: http://ecomodder.com/forum/showthrea...cyl-29176.html )
I ran out of time to do a couple more mods that I would have liked: cowl fairing; rear wheel skirts; taped over the holes in the wheelcovers.
Pretty good factory "mods" ...
Mitsu hasn't left as much low-hanging fruit on this entry level car as other companies do on theirs. The Cd. is 0.28 in North America, and comes with multiple factory aero elements like:
- drag-reducing spoiler/roof extension
- partial lower grille block off (and the size of blocked area is different for CVT vs manual)
- relatively smooth wheel covers (base model)
- narrow section LRR tires (165 mm)
- "optimized" rocker panel design
- sharp trailing edge/corner on the rear bumper cover
- plastic underbody panels
- front wheel/suspension deflectors
Here's what I added to that...
1) Grille blocks
This mod is less extensive than it looks, because Mitsu already blocked out about half of the "apparent" lower grille openings in the Mirage. I closed the upper slot plus a bit more than half of the lower openings.
2) Fog light inserts
Probably no real effect from covering these, but they looked lumpy and I had the plastic & tape out already, and so why not.
3) Air dam
Added a ~3 inch dam as far forward as I could, wrapping smoothly back to the front wheel arch on the sides. It left about 3.5 inches of clearance (and it scraped 3 or 4 times during the drive).
This mod is hard to do when you can't drill your borrowed car! Lots of tape (and later Goo-gone) used!
3) Passenger side mirror delete, driver's folded back
Replaced with a small (approx 2.5 x 3 inch convex mirror); folded the driver's mirror back and taped a convex mirror on its trailing end.
4) Passenger wiper delete
It parks unusually high and at an odd angle on this car (and on the Micra too, I noticed). Although it might also be angled so the local flow goes more from end than face-on. A quick tuft test would answer that.
5) Kammback/spoiler extension
This adds about 10 inches more to the roofline and up to 15 inches on the sides, and includes a notch to show the LED center brake light.
Testing...
I used my usual flat, straight 1.6 km test route. Conditions were perfect: 25C and dry, no wind at all. There was never any traffic ahead of me in my lane, but sometimes oncoming traffic went past on the other side.
I would have liked to do A-B-A, but didn't have time. Also, this car doesn't have cruise control, so I had to use laser focus on that speedometer needle. It's pretty easy to hold this car at a dead steady speed, but it did wander half a km/h or so up or down. So take all this with an appropriately sized grain of salt!
I did A-B-C, where...
- A was all mods in place;
- B
was all mods in place except the air dam;
- C
was all mods removed
Results ...
I removed the air dam separately because I was most curious about it. It was pretty much a given that all the other mods would help or have little effect, but the air dam had the potential to actually make things worse, and I wanted to check that.
The fuel economy improvement between unmodified (C) to modified (A) was 4.5 % @ 90 km/h / 56 mph based on these numbers.
A1 - 57.15 mpg US (average of 2-way run)
A2 - 56.8
B1 - 56.1
B2 - 56.15
C1 - 53.7
C2 - 55.0
C3 - 54.8
ID:	15165   Click image for larger version
ID:	15167   Click image for larger version
ID:	15168   Click image for larger version
ID:	15169   Click image for larger version
The Following 17 Users Say Thank You to MetroMPG For This Useful Post:
aerohead (06-10-2014), BamZipPow (06-10-2014), benphyr (06-19-2014), blownb310 (06-19-2014), California98Civic (07-16-2014), Daox (06-10-2014), ecoTex (06-09-2014), fusion210 (06-10-2014), jedi_sol (06-09-2014), mcrews (06-09-2014), mikeyjd (06-09-2014), niky (06-11-2014), PaleMelanesian (06-10-2014), sendler (06-20-2014), smallie (12-17-2020), SwamiSalami (06-19-2014), whatmaycome14 (07-10-2014)
Old 06-09-2014, 05:21 PM   #2 (permalink)
jedi_sol's Avatar
2013 STi *SOLD* - '13 Subaru Impreza WRX STi
Subaru
Sports Cars
Team Turbocharged!
90 day: 26.59 mpg (US)
1996 Geo Metro *RETIRED from Ecomodding* - '96 Geo Metro Base
90 day: 58.68 mpg (US)
No additional "A" run?
No cruise control?
BIG GRAIN OF SALT INDEED
See the rest of the Sti project log:
http://ecomodder.com/forum/showthrea...log-26612.html
The Following User Says Thank You to jedi_sol For This Useful Post:
Fat Charlie (06-10-2014)
Old 06-09-2014, 05:23 PM   #3 (permalink)
GIANT GRAIN of salt!
niky (06-11-2014)
Old 06-09-2014, 05:24 PM   #4 (permalink)
radiantthought's Avatar
Leaf on the Wind - '13 Nissan Leaf
Do you have any more photos? I'm curious to see how you secured a mirror to the back of the folded down driver's side mirror.
Old 06-09-2014, 06:43 PM   #5 (permalink)
jedi_sol's Avatar
Subaru
Sports Cars
Team Turbocharged!
It looks like the mirror is attached with a liberal amount of duct tape
Old 06-09-2014, 07:47 PM   #6 (permalink)
...beats walking...
Canadians don't need no stinking SALT, they're the PEPPER-of-the earth kind'o people (wink,wink)!
The Following 2 Users Say Thank You to gone-ot For This Useful Post:
mcrews (06-09-2014), niky (06-11-2014)
Old 06-09-2014, 07:49 PM   #7 (permalink)
mikeyjd's Avatar
Matchbox - '93 Ford Festiva L
Team Ford
Last 3: 70.16 mpg (US)
Salamander - '99 Chrysler Concorde LXI
Team Dodge
90 day: 30.3 mpg (US)
Urquhart - '97 Toyota Tacoma 4x4 V6 3.4L DLX
Pickups
90 day: 25.81 mpg (US)
Smudge - '98 Toyota Tacoma
90 day: 40.65 mpg (US)
Calebro - '15 Renault Trafic 1.25 dci
90 day: 39.39 mpg (US)
Cool
Old 06-09-2014, 09:50 PM   #8 (permalink)
You are correct, sir!
For the passenger side, I made a coroplast baseplate shape to fit where the mirror base was, and created a coroplast "pod" to which I attached the convex mirror. Of course, all held together and attached with liberal amounts of duct tape.
Old 06-09-2014, 09:52 PM   #9 (permalink)
Proof!
The Following 2 Users Say Thank You to MetroMPG For This Useful Post:
aerohead (06-10-2014), mikeyjd (06-09-2014)
Old 06-09-2014, 10:06 PM   #10 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
VERY SWEET!!!!
THe black gives it just enough contrast to be called a 'sports' model.
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
