Old 11-03-2021, 02:51 PM   #21 (permalink)
It's a vortex generator. Inside and out.
aerohead (11-03-2021)
Old 11-03-2021, 02:57 PM   #22 (permalink)
vortex generator
As in Dyson's 'cyclone-precipitator' ?
Old 11-03-2021, 05:10 PM   #23 (permalink)
Generically:
Cyclonic separation
Cyclonic separation is a method of removing particulates from an air, gas or liquid stream, without the use of filters, through vortex separation. When removing particulate matter from liquid, a hydrocyclone is used; while from gas, a gas cyclone is used.Wikipedia
Old 11-03-2021, 05:20 PM   #24 (permalink)
generically
Generically:
Is that what you were referring to?
Old 11-03-2021, 05:58 PM   #25 (permalink)
I was alluding to Dyson's proprietary rebranding.
That and the disruption down one side of the truck cab.
Old 11-03-2021, 06:09 PM   #26 (permalink)
side of truck cab
Sorry, I just couldn't make a connection between the filter cannister and a VG, even turned inside-out. I'll let that mental subroutine keep running.
Old 11-03-2021, 09:08 PM   #27 (permalink)
It's right there in the name. Cyclone = vortex.
aerohead (11-05-2021)
Old 11-05-2021, 10:13 AM   #28 (permalink)
cyclone - vortex
The distinction would be that:
* in the cyclone precipitator, higher-density ( than the air ) particulates are centrifuged outwards ( like pigs and cows in a tornado ) to the inner wall boundary layer of the enclosure, where gravity will ultimately carry them ( precipitate ) to the bottom for disposal.
* VGs create vortex lift along their longitudinal flow edges, as in the Space Shuttle, Concord SST delta-wings, and fixed on a boundary wall, this low edge pressure helps induce the downwash which helps the flow hug the contour. Not without some cost.
Old 11-05-2021, 12:47 PM   #29 (permalink)
That's why it's an allusion rather than a reference?
Old 11-08-2021, 01:59 PM   #30 (permalink)
Lots of Questions
Motor-Rolla - '01 Toyota Corolla LE
90 day: 28.3 mpg (US)
Gaia - '99 Toyota 4Runner SR5 Highlander
90 day: 19.78 mpg (US)
Gaia - Round 2 - '99 Toyota 4runner SR5 Highlander
90 day: 17.92 mpg (US)
Third piece, passenger side mid section.
Behind front tire:
From the front, inside the wheel:
In front of rear tire:
I had to fabricate my own brackets to attach the outside edges of the board to the underside of the steps. This really stretched my working knowledge as I've never fabricated anything metal before. I used a L bar from the hardware store, drill and tapped, used an angle grinder to cut them to size and and belt/disc sander to clean up the edges (just so there were no sharp burrs). I offset the holes so the bolts don't hit each other when installed.
Don't forget to like our Facebook page!
Best EM Quotes:
It has been said, that if you peel the duct tape back on Earth's equator, you'll find that the two hemispheres are held together with J B Weld.
Originally Posted by Dan9 View Post
subscribed with a soda.
If you're burning,and someone throws gasoline on you,there will be a localized cooling effect, but you're still on fire.
The Following User Says Thank You to jeff88 For This Useful Post:
aerohead (11-08-2021)
