Old 07-30-2014, 09:47 PM   #1 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Question Adjusting valve clearances
Adjusting valve clearances on my D16y7 Honda Civic 1998 Engine. Following the Honda FSM's directions, I measured the clearances with a feeler gauge tonight.
Three questions about the below "data."
QUESTION 1: How badly do you think such clearances effect emissions and/or FE?
QUESTION 2: When I go to adjusting can I leave #2 and #3 alone?
QUESTION 3: Should I be adjusting the valves for an optimum "feel" at 8 for the intakes and 10 for the exhaust, in other words right in the middle of spec?
Here is what I measured (numbers in parenthesis mean it seems tight or loose):
Cylinder #1
intake spec 7-9
left 6 right 7(6)
exhaust spec (9-11)
left 9 right 7(6)
Cylinder #2
intake
left 7 right 7
exhaust
left 9 right 9
Cylinder #3
intake
left 7 right 7
exhaust
left 9 right 9
Cylinder #4
intake
left 7(6) right 7
exhaust
left 9(10) right 9(10)
DukeEcoNukem (06-04-2016)
Old 07-30-2014, 09:57 PM   #2 (permalink)
I always set them to max specs, since they will wear to smaller clearance. That way you probably can get 60k out of the adjustment. Back off the lock nut, put the max spec feeler in place, spin the adjustment screw with your finger until it's snug then lock down the nut and recheck. After a couple you will geet a "feel" for the adjustment. Try the next higher blade to make sure they are not too loose. My VX was all in specs at 62k miles and they had never been touched before.
regards
Mech
The Following 2 Users Say Thank You to user removed For This Useful Post:
California98Civic (07-30-2014), DukeEcoNukem (06-04-2016)
Old 07-31-2014, 12:02 AM   #3 (permalink)
Cyborg ECU
That's surprising and great advice, thanks as always. It means I have to set them all, which is fine. How would you go about cleaning all the grime and caked carbon? I figure a little gentle manual scraping followed by a solvent on the inside of the valve cover but NOT on the valves and lifters because the solvent would get into the oil and such... maybe a plastic scrubbie could be used on the valve arms?
Old 07-31-2014, 02:11 AM   #4 (permalink)
Polymorphic Modder
SoobieOut's Avatar
2006 DaCivic Hybrid - '06 Honda Civic Hybrid
90 day: 45.16 mpg (US)
I took mine to the shop for adjustment, since it was starting to sound like a diesel.
FE improved, and sounds much better.
Old 07-31-2014, 12:36 PM   #5 (permalink)
Cyborg ECU
Clearance, overlap, emissions
The greater clearance you recommend (within spec) should reduce intake/exhaust overlap and therefore improve my emissions. It should also reduce unburnt fuel in the CAT. It will reduce fuel efficiency a little, though, correct? I'll lose scavenging and gain pumping losses, correct?
Here is some reading I am doing that gives me these thoughts/questions:
1- Gordon's Garage - Fast Cars or Clean Air?
2 - http://www.mechadyne-int.com/vva-ref...-emissions.pdf
Originally Posted by MorphDaCivic View Post
I took mine to the shop for adjustment, since it was starting to sound like a diesel. FE improved, and sounds much better.
That's encouraging. But I can't go to a mechanic. I have to do it myself for the sake of the family budget plan. "Be the mechanic you wish to see in the world" is my mantra.
Old 07-31-2014, 01:52 PM   #6 (permalink)
I wouldnt try to clean any "gunk" off the rockers or use any solvent that could cause the valve seals to loose their integrity and you start burning oil. The inside of the valve cover, no problem.
regards
Mech
California98Civic (07-31-2014), DukeEcoNukem (06-04-2016)
Old 07-31-2014, 02:15 PM   #7 (permalink)
sarguy01's Avatar
Mazda5 - '12 Mazda 5
90 day: 25.22 mpg (US)
Big D - '11 Dodge Durango Crew
90 day: 18.75 mpg (US)
Well, I used Marvel Mystery Oil on my 200,000 mile Metro. If Seafoam is "colon blow", Marvel Mystery Oil is a "gentle cleanse". I know if there are seals on their way out, but crud keeping the oil from leaking, Seafoam can clean the crud and allow those seals to start leaking.
The Metro had one cylinder that was around 100 psi when I got it. After 3,000 miles of one quart MMO and three quarts Mobil One, the compression had gone up. I think it was due to cleaning the lifters out and allowing them to fully flow oil in and out of them.
I also MMO'd the Civic when I first got it. I ran it for 5,000 miles. One quart MMO and three quarts M1.
The Metro forum folks swear by MMO to slowly clean out the inside of engines. It might be something to look into.
The Following 2 Users Say Thank You to sarguy01 For This Useful Post:
Old 07-31-2014, 02:51 PM   #8 (permalink)
Furry Furfag
Baltothewolf's Avatar
Winsight - '00 Honda Insight
Miaderp - '95 Mazda Miata
90 day: 28.53 mpg (US)
While we are on this subject, do any of you know if it's safe to seafoam a D16Y5 engine? I don't want to destroy my engine seafoaming it. Autozone is having a 'buy 2 get 1 free' deal and if so, I think I'll pick up a few.
Old 07-31-2014, 03:28 PM   #9 (permalink)
Cyborg ECU
I wouldnt try to clean any "gunk" off the rockers or use any solvent that could cause the valve seals to loose their integrity and you start burning oil. The inside of the valve cover, no problem....
Thanks, man! Will do.
Well, I used Marvel Mystery Oil on my 200,000 mile Metro. If Seafoam is "colon blow", Marvel Mystery Oil is a "gentle cleanse". ...
I actually do use the MMO, sometimes. But not in the oil anymore. Two years ago or I did once and it made me nervous because it was associated with an experience of a quart of oil loss over the course of a 6000 mile oil change cycle. It might not have been the cause, but it put me off the practice. I do put a little in the gasoline sometimes. Maybe I'll use MMO for cleaning the inside of the valve cover. That sure would be gentle. But I think I'll lay off the rockers and such, as Old Mech says.
Old 08-01-2014, 12:15 AM   #10 (permalink)
Cyborg ECU
Exhaust valve maximum clearance spec is 0.011in and the intake valve maximum clearance spec is 0.009. I set them all to those specs. I'll check again tomorrow. I'm wondering how tightly to torque these aluminum parts. It says 13ft/lbs. I tightened to hand tightness only, without using the ratchet handle.
