Old 09-23-2014, 07:58 PM   #1 (permalink)
SilverCrown9701's Avatar
SilverCrown - '01 Toyota Camry LE
90 day: 35.32 mpg (US)
Arrow Is this true? (Instantaneous MPG higher at 60-65 versus 50-55 using DWL)
I've been observing my UltraGauge for the past few weeks and I notice that my Instantaneous MPG value goes higher at 60-65 versus 50-55 using DWL and no A/C with a throttle position below 18. It also causes my Average MPG value to rise and my Instantaneous Gallons Per Hour stays relatively the same.
Is it possible that my vehicle gets better mileage at higher speeds with low-moderate throttle position??
The name "Camry" is an Anglicized phonetic transcription of the Japanese word kanmuri meaning "crown".
Old 09-23-2014, 08:15 PM   #2 (permalink)
Yes, add some P&G and watch it go even more.
The Following User Says Thank You to Cobb For This Useful Post:
SilverCrown9701 (09-23-2014)
Old 09-23-2014, 08:36 PM   #3 (permalink)
101Volts's Avatar
Woody - '90 Mercury Grand Marquis Wagon LS
Last 3: 19.57 mpg (US)
Brick - '99 Chevrolet K2500 Suburban LS
Last 3: 12.94 mpg (US)
M. C. - '01 Chevrolet Impala Base
90 day: 18.73 mpg (US)
R. J. - '05 Ford Explorer 4wd
90 day: 16.66 mpg (US)
That's what I've been wondering about my Dad's 3-Litre Caravan. However, I don't have a lot of flat areas nearby that I know about to test this on being in Pennsylvania. I noticed that with the TPS being at 19, 20 or 21 and going at about 70 MPH on a Highway (There are some places where the speed limit is that high in PA) the Instant MPGs actually go in the upper 30s and lower 40s according to the ScanGauge II (Set at -5% or -4%)
That's with tires at 45 PSI, no roof-rack and with the middle and rear seats out.
The Following User Says Thank You to 101Volts For This Useful Post:
Old 09-23-2014, 08:43 PM   #4 (permalink)
Volt, gas only - '12 Chevrolet Volt Premium
90 day: 38.02 mpg (US)
Volt, electric only - '12 Chevrolet Volt Premium
90 day: 132.26 mpg (US)
Yukon Denali Hybrid - '12 GMC Yukon Denali Hybrid
90 day: 21.48 mpg (US)
Its possible, but I would challenge you to do more "controlled" experiments and compare data.
The Following 4 Users Say Thank You to ksa8907 For This Useful Post:
MetroMPG (09-24-2014), PaleMelanesian (09-24-2014), SilverCrown9701 (09-23-2014), Xist (09-24-2014)
Old 09-23-2014, 09:16 PM   #5 (permalink)
Its has something to do with the map people post that shows a grid pattern, then a bunch of circles like a topographic map with rpms vs engine load. There is a magic speed or gearing vs load you get best mpg, then it drops like a rock.
The Following 2 Users Say Thank You to Cobb For This Useful Post:
Old 09-23-2014, 11:32 PM   #6 (permalink)
My stock speedometer is only off by about 3 MPH, so I know that my speed isn't much different than what is shown. If I keep my load light and stay in overdrive, then my MPG increases according to my UltraGauge.
I've tried different loads, throttle positions, DWL versus cruise control, acceleration techniques.....it seems that 60 MPH is the magic number but I will continue to test. I will know on my next fillup if it has helped at all.
My Camry has a MAP sensor as well.
Old 09-24-2014, 12:55 AM   #7 (permalink)
Where do HX drivers get their best mileage?
Old 09-24-2014, 02:03 AM   #8 (permalink)
herp derp Apprentice
Saturn-sold - '99 saturn sc1
Team Saturn
90 day: 28.28 mpg (US)
Yukon - '03 GMC Yukon Denali
90 day: 13.74 mpg (US)
Sounds like you should create and post a chart to http://ecomodder.com/forum/showthrea...you-15182.html
Old 09-24-2014, 07:43 AM   #9 (permalink)
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
I don't think I've seen any Speed vs MPG chart for a conventional vehicle where the most efficient speed is 60Mph, especially with an automatic.
Relying on OBD instrumentation for instantaneous fuel consumption is a bit daft if you think about it.
If you really want to know, fill up, drive a 100miles at X speed and repeat.
Old 09-24-2014, 10:27 AM   #10 (permalink)
90 day: 51.82 mpg (US)
It's really unlikely.
Watching the "instant" MPG gauge is problematic. It moves around too much to be very useful in predicting overall MPG, and we tend to cherry-pick observations that lead to confirmation bias.
If you look at our collection of speed vs. MPG graphs, the dominant pattern for normal venicles is: best cruising MPG typically happens at the lowest speed in top gear.
2002 Camry automatic:
mort (09-24-2014)
fuel economy, speed, ultragauge
