Old 11-06-2008, 04:17 PM   #1 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
A first? BMW concept vehicle preheats transmission fluid to improve efficiency
Via GCC:
This is actually an old article; not sure why I stumbled across it.
Except I noticed in the illustration: "Solar roof for pre-warming of transmission fluid"
I wasn't sure at first if it was photovoltaics or thermal. Of course, it's PV:
The concept car also features a solar roof which acts as an additional energy source for the vehicle power supply which is independent of the engine. High-power solar cells covering a surface area of some 1.0 square meters generate a maximum energy of one kilowatt hour for consumers inside and outside the vehicle. This enables pre-heating of the gear oil, thereby shortening the inefficient warm-up phase.
The roof can contribute power to other systems too.
This is the first I've ever seen the idea of prewarming a transmission from a manufacturer.
Old 11-07-2008, 02:01 AM   #2 (permalink)
DMC - '99 Honda Civic DX
I like how they are improving on old technology instead or inventing something new.
Seriously the ICE needs to die. It's ancient.
Old 11-07-2008, 02:39 AM   #3 (permalink)
I know it sounds brilliant on paper but trust me. BMW always finds a complex solution to a simple problem that is guaranteed to fail on spectacular and unexpected ways. Somehow 'keep it simple stupid' never got translated into German. I know. I've owned 3 thus far. The fewer the cylinders, the more fun you have.
The internal combustion engine will outlive you by at least a century.
Old 11-07-2008, 05:52 AM   #4 (permalink)
Johnny 5 - '81 Honda Cm400e
90 day: 42.86 mpg (US)
Da bike - '06 Honda Shadow Vlx deluxe
90 day: 59.47 mpg (US)
true, just like the tired old wheel
Effect of gear oil viscosity on transmission efficiency (Metro owners take note) MetroMPG EcoModding Central 44 12-08-2014 11:22 PM
Flashing yellow light skyl4rk EcoModding Central 5 08-01-2010 01:57 PM
Honda Insight Concept to Debut at Paris Int. Auto Show SVOboy EcoModder Blog Discussion 32 04-17-2009 10:45 AM
