Old 02-07-2011, 08:57 PM   #1 (permalink)
Altering Tire Rolling Resistance
It occurred to me today that I might lower the rolling resistance of my tires by cutting the tread blocks across the tread so that they were, by say, 1/2 or 1/3 as long, along the direction of travel. By doing this, I submit that the work of bending the tread as the tire enters and leaves the contact with the pavement would be reduced. I would propose to cut them to the depth of the tread. I think this would accelerate the wear rate during acceleration and braking, but then I am no tire engineer. I know we have actual tire engineers on this site, what do you guys think?
Since I got my Ohatsu Negotiator 155/80R13 tires that are rated for 51 psi, I have been able to get 64.6 mpg out of my '81 Diesel Rabbit. Since then I put on a four into one header, with a 2 1/4" system with a Flowmaster 50 series muffler. That was the most spectacular power increase I have ever seen, the top speed went up at least 10 mph! WOW! Inlet work and a new tall geared tranny are next. I should be able to lower engine speed at cruise by ~30%. Anybody got a spare long legged 020 VW tranny?
Old 02-07-2011, 09:09 PM   #2 (permalink)
He ain't gonna die!
The Rooster's Avatar
Tree Catcher - '94 Acura Integra LS
90 day: 32.12 mpg (US)
The Old Dog - '92 Honda Accord LX
90 day: 31.58 mpg (US)
What you are describing is called siping, and is done to increse traction in mud, snow, wet, or otherwise low traction conditions. It's a process that was actually patented in 1923 by John F Sipe. The effect on fuel economy and tire wear have usually shown to be neutral, however handling on dry conditions can be compromised, making your tires feel squirmy or soft, which is why slicks are used in dry racing environments, and a lot of sport tires have very large tread blocks.
She was beating on my door for two hours last night...but I wouldn't let her out.
Old 02-07-2011, 09:13 PM   #3 (permalink)
I think it would have opposite the intended effect as it would promote even more flexing than without, and it is the flexing of the rubber than causes the r.r. losses.
I've sometimes wondered if filling inbetween the tread blocks with silicone rubber or ? would reduce r.r....?
Old 02-08-2011, 08:50 AM   #4 (permalink)
Tire Geek
CapriRacer's Avatar
Originally Posted by Crazyrabbit View Post
It occurred to me today that I might lower the rolling resistance of my tires by cutting the tread blocks across the tread so that they were, by say, 1/2 or 1/3 as long, along the direction of travel. By doing this, I submit that the work of bending the tread as the tire enters and leaves the contact with the pavement would be reduced. I would propose to cut them to the depth of the tread. I think this would accelerate the wear rate during acceleration and braking, but then I am no tire engineer. I know we have actual tire engineers on this site, what do you guys think?......
The stiffness of the tread is very minor compared to the stiffness of the belt, so anything done to the tread stiffness would have a minor effect. If anything, you'd want to increase the stiffness of the tread in the longitudinal direction.
But you've proposed removing tread rubber and that would have a positive affect. Better would be to remove tread rubber along the grooves - perhaps cutting off the corners.
........I've sometimes wondered if filling inbetween the tread blocks with silicone rubber or ? would reduce r.r....?
That would be adding mass - which would not be good. If you are thinking that you would be reducing the movement of the tread elements as they move through the footprint - that is a very minor affect as well and it's the belt that pretty much controls that.
The Following User Says Thank You to CapriRacer For This Useful Post:
Frank Lee (02-08-2011)
Old 02-08-2011, 09:42 AM   #5 (permalink)
Thanks for the comments. Just to clarify, I was not proposing to remove any tread. I was thinking of just slitting across the tread blocks to the depth of the tread, so that at the beginning and end of contact the slit would open reducing the amount of flexing in the tread block. I would not expect this to have much impact on handling, but would expect the tread to deflect more due to braking and acceleration and therefore wear more.
Old 02-08-2011, 11:36 AM   #6 (permalink)
He ain't gonna die!
As I explained earlier, it very much does have an impact on handling. You are describing a process called "siping" that is practiced often in cold climate area's, when I lived in Washington, Les Schwab would sipe your tires for free when you purchased them if you wanted them to. The process has provent to improve handling, acceleration and braking on ice, snow, mud and wet conditions, however the tires become very spongy, almost slimy feeling when driving on dry surfaces.
Old 02-08-2011, 12:11 PM   #7 (permalink)
Tire Geek
CapriRacer's Avatar
Ok, so no change in the amount of tread rubber - so that makes it "Going in the wrong direction".
155/80r13, hyper-inflation, low rolling resistance
