Old 05-11-2012, 12:54 AM   #1 (permalink)
EcoModding Enthusiast
blackcivic96's Avatar
Jeepper - '97 Jeep Wrangler Sport
90 day: 19.96 mpg (US)
White Gen II Prius - '06 Toyota Prius
90 day: 57.68 mpg (US)
Alternate Front End Gap filler
So I added this to another thread, but I am re-posting here, anew.
I have an aftermarket headlights and aftermarket front bumper (from an accident 2 years back), so the seams aren't exactly "tight". So while at Menards I saw something that may work, flex PVC. Seen below. The size purchased will depend on the gaps that are being filled, but I picked up 1/2" OD, cost ~$2.00 for 10'.
And here's the gap to be filled, upper left of the headlight.
Now the nice thing about this PVC, is that is it is quite mailable and can be manipulated to fit the gap. I squeezed it then pushed it in (the warmer it is the better), filling the gap. Then it expands for a tight fit.
Nice, clean and cheap!
Now if your car isn't black like mine and you are worried about the color, pick up the clear type, you won't see it as much.
Word of caution: These may fall out in the "auto" carwash, or at high speeds, depending how tight the fit is. Also as mentioned above it gets soft with heat, so be aware of that as well.
-Dave
Old 05-11-2012, 09:55 AM   #2 (permalink)
Deadly Efficient
Tango Charlie's Avatar
Olivia - '03 Pontiac Vibe base
90 day: 36.01 mpg (US)
R2-D2 - '00 Honda Insight
90 day: 58.81 mpg (US)
I'm sure that you could coil it up into an envelope and mail it, but I think you meant to say that it's "malleable".
Hey, that looks pretty good. Even with a different body color, the black may not look too bad, since it's at a visual break point between the fender and the headlight.
-Terry
Old 05-11-2012, 10:28 AM   #3 (permalink)
Yup, damn spell check
Old 05-11-2012, 02:57 PM   #4 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
BZP T-100 (2010) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 24 mpg (US)
BZP T-100 (2011) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 23.66 mpg (US)
BZP T-100 (2009) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (2012) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 25.45 mpg (US)
BZP T-100 (2013) - '98 Toyota T-100 SR5
Last 3: 25.79 mpg (US)
BZP T-100 (2014) - '98 Toyota T-100 SR5
Last 3: 23.18 mpg (US)
BZP T-100 (2015) - '98 Toyota T-100 SR5
Last 3: 23.85 mpg (US)
BZP T-100 (2016) - '98 Toyota T-100 SR5
Last 3: 17.62 mpg (US)
BZP T-100 (2017) - '98 Toyota T-100 SR5
90 day: 20.78 mpg (US)
BZP T-100 (2018) - '98 Toyota T-100 SR5
90 day: 20.19 mpg (US)
BZP T-100 (2019) - '98 Toyota T-100 SR5
BZP T-100 (2020) - '98 Toyota T-100 SR5
2012 Scion iQ - '12 Scion iQ Base
Send a message via ICQ to BamZipPow
Talking
It could've been "mall-able"...that is good enough to go to the mall with.
Dark Aero-The world's first aerodynamic single wheel boat tail!
Old 05-12-2012, 10:46 PM   #5 (permalink)
Thanks!?
Old 05-13-2012, 04:32 AM   #6 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
Originally Posted by blackcivic96 View Post
Thanks!?
Just messing with yah...no malice was intended.
Old 05-15-2012, 06:28 PM   #7 (permalink)
Sven7's Avatar
Boo Radley - '65 Ford F100
90 day: 13.28 mpg (US)
So the big question is, will this little tube save you $2 in gas?
Old 05-17-2012, 12:06 AM   #8 (permalink)
Sven,
I have no idea. I was used about half of it trying to find the best way to fit it, initially I cut a slice down the middle, which worked but slide right off. But I was able to seal up the majority of large gaps.
I am working to increase my Cd as I have hit my limit at about 49mpg on the highway +/-. So I am hoping this among other changes will help. Slowly but surely
-Dave
Old 05-17-2012, 02:50 PM   #9 (permalink)
That VX guy!
TomO's Avatar
The VX - '92 Honda Civic VX
Send a message via AIM to TomO Send a message via Yahoo to TomO
That looks like something that Honda would do, looks nice and OEM style!
Ever consider Seal 'n Peel?:
From Home Depot :Seal 'n Peel
you could actually use it to seal up the edges of the quarter panels to the doors, edges of the hood to fender, and trunk edges and such, let it cure and then peel up only one side so the doors and hood could still open but he weatherstripping would stay to be able to fill the gap still.
Old 05-17-2012, 04:26 PM   #10 (permalink)
Very interesting. I'll have to check it out
