Old 10-13-2009, 08:35 AM   #11 (permalink)
Black Beauty - '09 Honda Accord EX-L
90 day: 27.44 mpg (US)
Originally Posted by dwtaylorpdx View Post
The main reason I was talking about this mod is that on a race car, this one mod makes a easily measurable difference at high RPM, so the assumption is that it somehow lowers engine load without actually modifying the alternator system other than location, if a car goes faster the easy assumption is its less parasitic at the lower RPM but would still charge the alternator. Removing the alternator is not an option on many cars. But reducing its use still is. You can protect the diodes with caps, not that hard.
Of course it simply may not pay off at the lower rpms on the street. May make way more sense to just increase the alternator pulley size to slow it down./
Dave
Ok, I look forward to seeing how this goes for you.
Pursuing new technology is what we all are striving to do!
Old 10-13-2009, 04:09 PM   #12 (permalink)
orange4boy's Avatar
The Golden Egg - '93 Toyota Previa DX
90 day: 31.91 mpg (US)
Chewie - '03 Toyota Prius
90 day: 57 mpg (US)
The Spaceship - '00 Honda Insight
Interesting idea if a bit complicated.
couple of things to look out for:
1) Will you be able to supply enough juice to both run the electrics and charge the battery if you are only going to turn on the alt during certain conditions? Many cars undercharge as it is on short trips. You might need to top up at home with an automatic charger. ( a good idea in any event to prolong battery life) The float charge on a battery, which is required for long life, takes about an hour.
2) Alternators are less efficient and have lower amp capacity at low RPMs
Better have an ammeter to keep a lookout for discharge conditions.
Vortex generators are old tech. My new and improved vortex alternators are unstoppable.
"It’s easy to explain how rockets work but explaining the aerodynamics of a wing takes a rocket scientist.
Old 10-13-2009, 05:04 PM   #13 (permalink)
I would like the idea if he implemented a "Pancake" style alternator that surrounds the driveshaft. The alternator would always be spinning and have no need for belt operation thus increasing efficiency.
Repepping the CRX (plans and advice thread) SVOboy EcoModding Central 33 09-01-2009 06:22 PM
Build Thread Key Postings Index Experiment. TestDrive Forum News & Feedback 7 02-15-2009 08:53 PM
The UnNamed Wagon's build thread - Let it begin! Work in Progress XFi EcoModding Central 38 08-01-2008 12:21 AM
Change a thread title? wagonman76 Forum News & Feedback 3 06-27-2008 06:40 PM
