Old 06-22-2016, 05:49 PM   #1 (permalink)
Throttle Body Spacer
So, I have the 2016 Toyota Corolla LE ECO 1.8L 2ZR-FE engine. Would adding a throttle body spacer help my fuel economy? I really don't care about top speed. I just want the torque range more in the lower rpm band like 1,000-2,500 rpm range. Any way that putting one in would do that? Any other way to lower the torque band to the lower rpm range?
Old 06-22-2016, 06:20 PM   #2 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
here I did alittle research for you........
"Type of Engine
These spacers mainly benefit older engines. In particular, those with fuel injection systems that have the fuel go directly into the throttle body, where it then mixes with air before going into the combustion chamber. It also can help with carburetor systems. However, if the vehicle has a multi-port fuel injection system or other top of the line system, then that small change in the air vortex will not make any difference to the performance, torque or horsepower. Therefore, before you go out and purchase a spacer, make sure your engine can actually benefit from having this upgrade."
I believe the answer is NO.
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
The Following 2 Users Say Thank You to mcrews For This Useful Post:
Joggernot (06-23-2016), Xist (06-22-2016)
Old 06-22-2016, 06:31 PM   #3 (permalink)
Ok, Thank you. I tried reading through the tread on here about them, but just couldn't wrap my head around it. This is probably the simplest answer I have heard yet. Thank you
The Following User Says Thank You to GK13 For This Useful Post:
mcrews (06-22-2016)
Old 06-22-2016, 07:06 PM   #4 (permalink)
mcrews's Avatar
I googled on the net. It was the first one I read....I got lucky!
ECO MODS PERFORMED:
First: ScangaugeII
Old 06-22-2016, 07:35 PM   #5 (permalink)
Ooh ooh ooh! What about me?! My car is older!
Old 06-22-2016, 07:37 PM   #6 (permalink)
Sport Utility Prius - '10 Toyota Prius II
90 day: 52.98 mpg (US)
300k Sequoia 4WD - '01 Toyota Sequoia Limited 4wd
90 day: 20.19 mpg (US)
Mechanically, that car is pretty close to optimized already. I'd try and focus on other areas. Here's an easy first step: Pump your tires up to the ever so popular 45psi. I noticed a good 3-4% gain going from 32 to 45.
"I feel like the bad decisions come into play when you trade too much of your time for money paying for things you can't really afford."
The Following User Says Thank You to hayden55 For This Useful Post:
mcrews (06-22-2016)
Old 06-22-2016, 09:23 PM   #7 (permalink)
mcrews's Avatar
you beat me to it!!!
ECO MODS PERFORMED:
First: ScangaugeII
Old 06-22-2016, 09:39 PM   #8 (permalink)
There may be a 3.5±.5% increase in efficiency going from 32 - 45, but I am pretty sure that there would not be a discernible improvement increasing from 44 - 45.
By the way, I did a Google search, and someone showed a horsepower increase on a dynamometer for a similar Civic, but I still do not care!
Old 06-22-2016, 09:40 PM   #9 (permalink)
I am keeping them at the sidewall max since I bought the car.
Old 06-23-2016, 04:21 AM   #10 (permalink)
You do not have the 2ZR-FE, you have the 2ZR-FAE. It does not even use the throttle body under normal operation!
