Old 05-01-2011, 08:49 PM   #1 (permalink)
Easter McoModder
SwamiSalami's Avatar
'99 Subaru OLL 2.5L - '99 Subaru Outback Legacy Limited
90 day: 22.57 mpg (US)
Rabbit - '08 VW Rabbit S
90 day: 32.93 mpg (US)
VW Rims
Curious about wheel covers I found online. Are these the kind that only work in place of "hubcaps" I've only ever had "rims" (pictured below).
Thanks for expertise.
Look forward to hearing from some of you!
Old 05-01-2011, 08:58 PM   #2 (permalink)
Fairly sure they will only work with steel wheels.
regards
Mech
The Following 2 Users Say Thank You to user removed For This Useful Post:
Christ (05-02-2011), SwamiSalami (05-02-2011)
Old 05-02-2011, 10:53 AM   #3 (permalink)
Easter McoModder
Thanks. I know this seems like an elementary question.
Old 05-02-2011, 10:58 AM   #4 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
You can probably get some steel and cash to buy the covers in trade for your current wheels, if you really like the smoothie style.
Old 05-02-2011, 11:41 AM   #5 (permalink)
Easter McoModder
I do really like that and feel like that would help with my aerodynamics, but sheesh! that just seems like an awful lot of work.
I wonder how much more weight steel wheels are?
I also wonder if this would effect the resale value of my car?
:S
Old 05-02-2011, 01:54 PM   #6 (permalink)
metroschultz's Avatar
CPT SLO - '93 GEO Metro plainjane
90 day: 53.91 mpg (US)
SilverHairBeauty - '01 Toyota Avalon XL
90 day: 24.06 mpg (US)
Send a message via AIM to metroschultz
1]I wonder how much more weight steel wheels are?
:S
1] some steelie are less weight than the aluminum they replace.
2] yes, steelies are less value that "Rims". so save your rims and reinstall them when you go to sell the car.
When you are courting a nice girl an hour seems like a second. When you sit on a red-hot cinder a second seems like an hour. That's relativity.
Albert Einstein
The Following User Says Thank You to metroschultz For This Useful Post:
Old 05-02-2011, 01:56 PM   #7 (permalink)
Steel probably is heavier by a good margin. You can sort of fix this by going to a smaller wheel with a slightly taller tire to keep the same circumference, but unless you drive mostly in the city, the impact will be minimal.
If you're worried about resale, go to the junkyard and buy a set of steel, clean them up and paint them, and keep your alloy around.
When you sell the car, the extra set of wheels will actually increase the take price, AND you'll probably keep the smoothies, so you can put them on the next wreck you buy.
The Following User Says Thank You to Christ For This Useful Post:
Old 05-03-2011, 02:42 PM   #8 (permalink)
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
Some of us in snowy climates have our winter tires on extra steel wheels. You can buy new tires mounted on steel wheels at Tire Rack if you are going to a narrower tire size. FWIW, I have had trouble with some hubcaps, like the ones in your original post, coming loose. If you are getting junkyard rims, you could go with the aluminum racing disks and drill and tap the outside edge of the rim, and bolt them on. The tire bead covers and seals the holes.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
Old 05-04-2011, 02:54 PM   #9 (permalink)
orange4boy's Avatar
The Golden Egg - '93 Toyota Previa DX
90 day: 31.91 mpg (US)
Chewie - '03 Toyota Prius
90 day: 57 mpg (US)
The Spaceship - '00 Honda Insight
I'm with COcyclist. The original Moon Eyes attach with small screws and fit on the alloys so you can keep the low weight. They are aluminum.
I have the hubcaps you posted there on my Previa and they are very thin and easy to dent. I have had to fix them a couple of times because the "Grip Tite Fasteners" weren't gripping very tight any more. They needed to be bent out a bit. That said, they are inexpensive and I have not lost any. I would buy them again though, at $60 a set they are worth it but if I had alloys it would be the Moon Eyes.
Vortex generators are old tech. My new and improved vortex alternators are unstoppable.
"It’s easy to explain how rockets work but explaining the aerodynamics of a wing takes a rocket scientist.
Old 05-04-2011, 04:57 PM   #10 (permalink)
proof of concept
Perhaps you could fab up some temporary covers which would last long enough to demonstrate a mpg benefit or not,then make your decision based on results.
