Old 08-02-2009, 09:23 PM   #1 (permalink)
Another DIY EV controller
Circuit Cellar - The Magazine for Computer Applications
The main advantage is that a common industrial 3 phase motor can be used.
If America manages to eliminate obesity, we would save as much fuel as if every American were to stop driving for three days every year. To be slender like Tiffany Yep is to be a real hypermiler...
Allie Moore and I have a combined carbon footprint much smaller than that of one average American...
Old 08-03-2009, 02:44 AM   #2 (permalink)
PaulH
MPaulHolmes's Avatar
Those little buggers! They even did field oriented control! That has good behavior at low rpm and high rpm. It needs to do a few trig transformations, so you need something a little better than an ATMega8. I really want to try one of these.
kits and boards
Old 08-03-2009, 08:14 AM   #3 (permalink)
bjn
Common industrial AC induction motors have a pretty bad power to weight ratio compared to commen DC motors, I think. However, if it's possible to drive them with a higher frequency than 50/60 Hz then maybe they can produce more power (if the torque doesn't decrease too much with RPM).
How high much can you overrev a typical 3-phase AC induction motor before it breaks apart? at which RPM does the power curve start to decrease due to the torque curve falling too fast?
Old 08-03-2009, 11:10 AM   #4 (permalink)
Industrial motors are rated to operate continuously at their rating plus plenty of margin for overload. So in an EV, the motor would actually be much more powerful than its rating would indicate. As little as 7.5HP might be enough for an EV.
Maybe it's possible to make a small 2 phase version to allow the use of large appliance motors for something like power steering? Or to allow a common window A/C compressor be used for an EV heat pump?
Old 08-03-2009, 02:30 PM   #5 (permalink)
2k2Prot5 - '02 Mazda Protege5
90 day: 33.82 mpg (US)
He's still sayin 2500 dollars in components? Paul, what's your cost?
Old 08-11-2009, 02:28 AM   #6 (permalink)
PaulH
Hey Matt! Well, for the DC controller, for 1 offs, it's about $300. In bulk about $230 or so.
kits and boards
Old 08-11-2009, 08:26 AM   #7 (permalink)
Somebody ought to tell him he blew it. However, a 3-phase setup with IGBT's in the DIY realm is nice to see.
Old 08-27-2009, 11:58 AM   #8 (permalink)
blew it? How so? because cost is $2500? He got a development kit, and had to pay full cost for parts.... you could cut that cost by 1/3-1/2 in bulk.
Its essentially 6 DC controllers (2 for each phase, one neg, one pos).... so its got 6 times the overhead on the microcontroller, 6 times the gate drive, 3 times the current control, 6 times the voltage sensing, vector or volts/hz control. 6 high power gate drivers, 3 IGBT dual packs....you get the idea). A DC controller is fairly easy to do, if you can get the FET's or IGBT's to gate at the same time. Its just pure PWM. An AC controller is PWM and PFM.
And not to mention, he can now use off the shelf AC motors, that don't have to be rewound, so that cuts cost quite a bit. Forklift motors are limited in voltage and RPM, induction motors can go quite a bit higher and are much more widely available. Just go look for an industrial 208V motor, they're everywhere.
Travis Gintz
1986 Honda Electric VFR
www.evfr.net
Old 08-27-2009, 03:57 PM   #9 (permalink)
Originally Posted by frodus View Post
And not to mention, he can now use off the shelf AC motors, that don't have to be rewound, so that cuts cost quite a bit. Forklift motors are limited in voltage and RPM, induction motors can go quite a bit higher and are much more widely available. Just go look for an industrial 240V motor, they're everywhere.
Actually, industrial motors in the sizes we are interested in are either 208v or 480v since those are the common 3 phase industrial voltages. (Some are designed so they can be used on either by rewiring.)
Old 08-27-2009, 04:04 PM   #10 (permalink)
I didn't think that his cost was rolling in development kits, and since we're talking DIY then "bulk" is not really a factor. DIY mean batch or single... else you're not exactly D'ing IY.
I'd love to know his "second time around" production cost. One MAJOR savings area would be the IGBT drivers. Build them from scratch and save major coin. Those things are a niche market electronic device with high standards of reliability - read: expensive.
Electric car conversion: Project ForkenSwift MetroMPG Fossil Fuel Free 1056 12-14-2024 12:21 AM
DIY Open Source EV Charger bennelson Fossil Fuel Free 385 12-27-2011 02:46 PM
DIY EV DC/DC converter? NiHaoMike Fossil Fuel Free 6 04-12-2010 08:13 AM
Home Brew Challenge for Electric Geniuses (make a DIY electric motor controller) WaxyChicken Off-Topic Tech 42 08-19-2008 01:05 AM
Fun with Voltage Controller Heatsinks Dradus Fossil Fuel Free 14 05-02-2008 03:16 PM
