Old 12-02-2020, 10:17 PM   #41 (permalink)
Are waterboxers still ty2?
IIRC they're a T3, while only the Split and the Clipper are considered a Type 2
The Following 2 Users Say Thank You to cRiPpLe_rOoStEr For This Useful Post:
freebeard (12-02-2020), Isaac Zachary (12-30-2020)
Old 12-04-2020, 12:22 AM   #42 (permalink)
Juicy has the same set-up as the Escape Caravan we rented. Juicy's Youtube video of their van features:
Kitchen
I'd be the first to admit I'm a little slow, but I'm having a bit of a hard time figuring out why they designed the ladder to not touch the ground on their tent setup at first video. It'd be best to go to 6:50 to see this in action.
Old 12-04-2020, 01:41 PM   #43 (permalink)
Dark Egg - '12 VW Touraeg
I wonder if the ladder with just hangers and sitting on the ground was falling over when the oppucants of the tent got that van a rocking. If it's just attached to the van and flying off the ground, then it doesn't have to act like a kickstand.
Old 12-05-2020, 09:31 AM   #44 (permalink)
I don't know if it needs to go that far, just loading and moving around would be enough to detach the ladder in most vehicles today.
Old 12-05-2020, 01:45 PM   #45 (permalink)
This was Westfalia's solution:
https://www.vwispwest.com/cm/ZVW49-3.jpg
The best accident is no accident -- Elon Musk
Old 12-31-2020, 10:45 AM   #46 (permalink)
EV OR DIESEL
FarFarfrumpumpen - '03 Volkswagen Jetta Wagon GLS Premium
Quorra - '12 Tesla Model S P85
Send a message via AIM to dremd
I’ve owned a lot of vans, none got 30mpg, my first thoughts are
1) smallest shortest T1N Sprinter upper 20’s in MPG
2) Mazda 5 also upper 20’s but in gasoline
3) dodge caravan/ Chrysler town and country mid 20’s
I’ve owned 3x air cooled type 2 VW’s. Fuel economy was always terrible. Teens in MPg. I was also a teenager at the time so that didn’t help.
I’ve owned 7 Ford E series. Best Mpg is later 5.4 liter about 15 mpg.
Chevy / gmc vans have touched 20
My big sprinter gets 24-26 mpg. I’ve never owned a small one.
2012 Tesla Model S P85
2013 Nissan LEAF SV totaled by now deceased intoxacated driver.
2012 Nissan LEAF SV
6 speed ALH TDI Swapped in to a 2003 Jetta Wagon
Old 12-31-2020, 12:03 PM   #47 (permalink)
Here is a totally off the wall idea.
IF I was trying to reach those numbers, I would buy a 2000 Mercury Grand Marques like the one I owned a few years ago.
IT got 29/30MPG at 65MPH all the time I owned it. And that was with the stock rear end gears of 3.27, and could most likely do a little better with the optional 2.73 gears.
Then you make it into a Station Wagon. One that can sleep two. All other camping gear could be stored in the beep trunk well under the bed.
Rich
Old 12-31-2020, 12:17 PM   #48 (permalink)
On the other hand I am working and THINK I can break 20MPG at 75MPH in my custom 93 Full size van https://www.facebook.com/media/set/?...4247153&type=3
With a custom built 383 which has a low/mid RPM Cam running a custom cam with Roads Lifters, and ceramic coated pistons and cylinder heads for lean burn running, custom OBD1 computer with special chip, and I will be adding extra EGR to both lean out the A/F ratios, try to burn left over fuel, and help over come pumping loses.
Lastly I plan on adding a second over drive (old Borg Warner unit devoiced from a 3 Speed w/OD) allowing my high torque engine to run at 1600RPMs at 75/80MPH.
As we rarely cook food on a road trip, a ice chest serves us well, and as our outing rarely last more than week max, shower, or other things are not needed. And as I plan on spending any over night stays at say KOA type camp grounds where I can get A/C will be able to run a small heat pump A/C unit for comfort.
Where as my even super MPG 2000 Mercury GM only got 24/26 MPG at 75/85MPH 20MPG at those speeds will be great considering the great ride, comfort and load carrying of this van.
Rich
Old 12-31-2020, 12:50 PM   #49 (permalink)
EV OR DIESEL
If your considering a full size car, just buy a Model S. I’m comfortable sleeping in mine, no space for restroom facilities, but sleeps great, quiet efficient, and you will never be chased off for being a weird guy in a van.
2012 Nissan LEAF SV
Old 12-31-2020, 12:59 PM   #50 (permalink)
At one point I put a fresh rebuild in my 1961 Type II panel van (dual-port 1600, 40mm Solexes and a single extractor exhaust) and to break it in I drove over the Coast Range at 55mph. At 60 miles I filled up and it took exactly two gallons — so 30mpg.
It spent the rest of it's time on I-5 above 70mph (top was 85) and (as you say) 17mpg.
