My odyssey has a similar 35 mph / 50 miles restriction. Since I'm only coasting for distances well below 50 miles, I feel I can push the speed a bit higher. That said, the benefits to eoc diminish at higher speeds. Neutral coasting gets more and more efficient at higher speeds, because you have a fixed idle fuel consumption divided over an increasing distance covered. I don't bother at highway speeds.
* in the Ody. My manual Fit spends more time in EOC than it does running.
![](http://ecomodder.com/forum/fe-graphs/sig268a.png)
