Old 08-25-2008, 10:21 AM   #201 (permalink)
Boxy is Sexy
Z man's Avatar
xBox - '05 Scion xB
90 day: 40.85 mpg (US)
Send a message via AIM to Z man
Originally Posted by whokilledthejams View Post
You know, it's funny you mention that-- I'm starting to suspect the gasoline on this current tank is going to keep my mpg down a bit.
Well Shell happens to be the most common place to fill up that is not 711 (Citgo) or Sheetz. I swear those places have terrible gas.
There are only a couple BPs and Sunocos. I've only seen one Valero in my life!
Where did you get that stuff to block your grille?
Old 08-25-2008, 05:43 PM   #202 (permalink)
Boxhead
whokilledthejams's Avatar
Boxy Brown - '04 Scion xB
90 day: 35.48 mpg (US)
Send a message via AIM to whokilledthejams
Originally Posted by Z man View Post
Well Shell happens to be the most common, place to fill up that is not 711 (Citgo)or Sheetz. I swear those places have terrible gas.
I've mentioned it elsewhere, but I got my coroplast at a local sign shop. They gave me a couple of misprinted election signs, and some other miscellaneous scraps. I offered to pay for them, and they said, 'don't worry about it, just remember where you got it from,' and sent me on my way.
I may go back to them to buy a full sheet or two in the future, however, as I plan to surreptitiously aeromod my girlfriend's Intrepid, and make a rear-end pan for my xB.
Old 08-25-2008, 05:56 PM   #203 (permalink)
Boxy is Sexy
Z man's Avatar
xBox - '05 Scion xB
Yeah I need to find some of this stuff. I take it it's heat and water resistant?
Old 08-25-2008, 06:00 PM   #204 (permalink)
Boxhead
Water, yes. Heat, I'm not certain. I have some pretty close to my engine, but not in contact with it, and none close to my exhaust. In the Scion xA aeromod thread, NeilBlanchard posted pics of a rear-undertray on his xA, and I just asked about how it's holding up around the muffler. If it doesn't melt or start on fire under his car, he may be on to something.
Old 08-27-2008, 02:43 AM   #205 (permalink)
Boxy is Sexy
Z man's Avatar
xBox - '05 Scion xB
Your last tank was better than mine, nice job.
My next tank should be pretty awesome, you just wait.
So where can pick up some of this material? Lowe's or Home Depot I'm guessing?
Yeah something fairly heat-retardant would definitely be effective.
All the air passing under the car may help keep it a little cool.
Old 08-27-2008, 07:04 AM   #206 (permalink)
Boxhead
Like I said, I got mine at a sign shop. Others here have mentioned buying full sheets of it at sign shops, too.
Also, It's probably best to keep it away from exhaust pipes, particularly near the front of the car. Apparently, it'll do ok at the rear as long as it's not directly touching the exhaust pipe.
Old 08-27-2008, 12:28 PM   #207 (permalink)
Box Dreamer
xB Commuter - '04 Scion xB
90 day: 40.76 mpg (US)
Someone mentioned too high temperature in catalyst converter is not good, even it doesn't melt the coroplast. Must be very careful to cover the bottom....
Old 08-27-2008, 04:27 PM   #208 (permalink)
Boxy is Sexy
Z man's Avatar
xBox - '05 Scion xB
I don't know of any sign shops.
But any undertray should be a benefit.
Hmmm.
We should post some xB pics!
I will have some soon.
Old 08-27-2008, 09:24 PM   #209 (permalink)
Box Dreamer
Another 43mpg today!!! Without major aero mod (only lower grille blocked), it is pretty good. SGII is still in calibration. Now is 5% overrated, which is pretty closed. Next tank, I will try turning off engine in long traffic light (e.g. 3 way) See how it affects mpg. Since I drive 80% freeway, I don't think it will increase mpg a lot, hopefully, to 44mpg. I will install the shock this weekend.
Old 08-28-2008, 12:14 AM   #210 (permalink)
Boxy is Sexy
Z man's Avatar
xBox - '05 Scion xB
Wow, 80% freeway? I'm lucky to get 50%!
But you have much more traffic over there, haha.
I can't believe I was at 260 miles at the half mark and only hit 43mpg?
driving techniques, mod, mpg, scion xb
