Old 04-17-2018, 06:46 PM   #11 (permalink)
Heavy images!
I have four elevator bolts and I think I have glued them to the roof five times each. I believe I am approaching the point of diminishing returns, but feel the dents are much less obvious now. I have been using Gorilla Glue sticks, which Wal-Mart only had available in minis, and I gave up on Wal-Mart's mini glue gun and started cutting off an inch of glue stick, melting the end, positioning it on the roof, and melting the rest with my heat ray, but I think I have been overdoing it, needing to hold the elevator bolts for the full minute it takes the glue to harden seems excessive.
I have used this on a friend's fender, my fender, a barbeque lid, and various other parts of my two Hondas. The glue keeps releasing from the bolts and staying on the roof. If I wanted to pull the same spot again I remeltedit. You are not supposed to do that, but I am having difficulty removing it.
Unfortunately, one of my last pulls popped off the roof, but stayed on the bolt.
It has a small flake of paint.
Right now I am going to worry about removing the hot glue and working on other projects. Normally the glue just peels off and sometimes I need to use a plastic scraper. People argue whether you should use acetone, censured alcohol, or isopropyl alcohol to remove hot glue. I had a spay bottle with one of those, but I am not sure where it is, or if it evaporated.
Pictures:
ID:	23937   Click image for larger version
ID:	23938   Click image for larger version
ID:	23939   Click image for larger version
ID:	23940   Click image for larger version
ID:	23942   Click image for larger version
ID:	23943   Click image for larger version
ID:	23944   Click image for larger version
ID:	23945   Click image for larger version
Old 04-17-2018, 06:58 PM   #12 (permalink)
This is a different angle, but I think this is before I started meddling:
This is the same area:
Piotrsko (06-11-2019)
Old 06-09-2019, 09:20 PM   #13 (permalink)
Gorilla Glue hot glue held better than the five other brands that I tried, but it hardly came off when I used acetone, 91% isopropyl alcohol, or denatured alcohol. I kept spraying it with 91% iso and using my plastic scraper when I realized there were tons of scratches in the clearcoat.
It should not be too difficult to redo the clearcoat, but I still did not remove the last of the hot glue.
I sanded it off.
I removed the passenger seat, used a floor jack, three-foot pipe, flange end, and hockey puck to push out some of the dents, but it only really worked when I could get the flange and hockey puck to match the curve of the roof, and it was difficult to get the floor jack to work with that.
I was not sure how to continue with the hot glue method. I broke two bridges previously and the one that I made from a zinc bar worked well, but it seemed like if I kept using it, the feet would create dents. I put a handle on the elevator bolts and pulled the best that I could, but I was only able to put so much force on it.
I bought this kit: $30 PDR slide hammer
I do not want to try the kit on the roof until I sand it some more, but I tried it on the hood. The light changed and I need to figure out something like the lights and stripe boards I see in the video. I put down four tabs, the three circles, which are larger than any tabs that I have seen, and bigger than I expected, and a large football-shaped one.
I think that it is for creases. There is a recess down the middle. I am not sure how that is supposed to help with creases.
Anyway, the football-shaped one popped off the first time that I pulled on it. Another popped after ten or fifteen pulls. The other two did not come off until I sprayed them with 91% isopropyl alcohol and used the slide hammer.
The hot glue does not peel off like normal stuff. When I sprayed it with alcohol and used a plastic scraper it broke up and made a mess. There is still black hot glue in a couple different spots. It definitely comes off easier than Gorilla Glue, but I do not think it holds as well, either.
The kit also comes with yellow glue sticks, which are supposed to hold better.
We will see how the slide hammer works with that stuff and the other products that I have bought.
Everything but Gorilla Glue.
The system seemed to work, but I still need to figure out to check the surface effectively.
RustyLugNut (06-10-2019)
Old 06-10-2019, 12:43 AM   #14 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
looks like significant improvement.
Xist (06-10-2019)
Old 06-11-2019, 12:51 AM   #15 (permalink)
Some progress.
Okay, seriously, what is the problem with the uploader? I uploaded it normally and it rotated, so I rotated it the other way, it rotated 180°, and that third try did not work so well, either.
I used hot glue sticks from the dollar store and they worked well enough, but the mini gun does not put out enough heat for the large tabs. However, the cheap glue helped pull up the black glue.
I am not sure that I can improve it any further, but it is less noticeable.
There seem to be some subtle ridges on the hood and roof, so I think I will use my bridge again. Hopefully I can push down the ridge, pull up the dent, and not dent the other side.
I worked on the roof, although I am not sure that it did any good, although it did not damage the paint [further]. Someone complained that the glue sticks that came with their slide hammer damaged the paint on their Chrysler 200.
Apparently their Chrysler 200 has worse paint than my twenty year-old Honda.
I moved to one of my old full-sized glue guns with sticks from Dollar general. They charge 45¢ each for a pack of ten. The gun jammed, so I disassembled it, and the spring sprung into the endless chaos of the garage that Mom refuses to organize. The trigger on the other one was broken, so I took it apart, reattached the spring, screwed it back together, and the first time that I tried to use it, the spring popped loose, and I needed to operate it by shoving the stick into the gun, while maneuvering the tab.
It really did not work well.
I am now the proud owner of a $9 Walmart glue gun, but it is too late to work.
Their glue sticks are 25¢ each for bags of 24.
ID:	26147   Click image for larger version
ID:	26148   Click image for larger version
Name:	Accord hood dents.jpg
Old 06-11-2019, 10:21 AM   #16 (permalink)
Harbor fright heat gun for maybe $9. Use to add , remodel, or remove glue. Buy your glue from big store fabric craft places, with a 20% off coupon.
Old 06-11-2019, 11:03 AM   #17 (permalink)
Walmart is the big fabric store in the area and I already have a heat ray, but you are right, it should work--or my plastic scraper, if I could just find it. I have been using a kid's shovel that I bought to stir homemade root beer for my fortieth birthday.
Edit: I thought it might be too early to use my slide hammer, but I wanted to use my bridge puller.
Here I go!
