Old 12-18-2017, 01:53 PM   #1 (permalink)
Anyone tried Firestone Champion Fuel Fighter tires?
My new-to-me Mirage came basically with drag slicks. So, I'm looking into tire options. Fortunately and unfortunately, it has an odd tire size (along with the Honda Insight) of 165/65 R14. This means I could mount RE92s on it, but they're also pretty pricey.
So, I'm looking at replacing them with the Firestone Champion Fuel Fighter in 185/60 R14s instead. This would give me a bit more grip and hopefully maintain most of the LRR goodness.
TireRack has a test of them here:
https://www.tirerack.com/tires/tests...y.jsp?ttid=220
But, I'm hoping someone here with a more fuel efficient mindset can shed some light on these tires. Thanks!
Old 12-18-2017, 09:16 PM   #2 (permalink)
nemo's Avatar
Chief - '06 Pontiac Grand Prix
90 day: 26.7 mpg (US)
SF1 - '12 Ford Fiesta S
90 day: 30.95 mpg (US)
The Firestone Champion Fuel Fighter is what I'm running on the GP. Have less than 1000 miles on them. They seem to roll easier than the Goodyear Eagles that were on it. But can't give you any numbers as there is no commute or routine drives for this car.
Old 12-18-2017, 11:15 PM   #3 (permalink)
Volt, gas only - '12 Chevrolet Volt Premium
90 day: 38.02 mpg (US)
Volt, electric only - '12 Chevrolet Volt Premium
90 day: 132.26 mpg (US)
Yukon Denali Hybrid - '12 GMC Yukon Denali Hybrid
90 day: 21.48 mpg (US)
Going by info on tirerack, you'd be crazy not to buy the altimax rt43. Then again, I always prioritize wet grip over just about all other parameters. My $.02
Old 12-19-2017, 07:06 AM   #4 (permalink)
90 day: 39.72 mpg (US)
90 day: 59.95 mpg (US)
To my knowledge, in 165/65r14 you have Michelin Energy Savers (usually $90-100), Dunlop Enasave ($115) and Potenza RE92 (~$80). None of these ever struck me as particularly expensive because their 185/65r14 counterparts (used by Prius, Corollas and Civics) were always more expensive.
EDIT: Anyway, with a low-powered car like my Insight, putting on oversized or non-LRR tires literally lowers top speed in 5th gear, so you'd be crazy to do it.
Old 12-19-2017, 08:03 PM   #5 (permalink)
Big Dave's Avatar
The Red Baron - '00 Ford F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Chevrolet Impala SS
90 day: 21.03 mpg (US)
I used them on my Impala for a number of years.
Didn't seem to affect MPG. Never used them in winter (car not Ziebarted).
OK tires.
Not much ever affected the Impala's MPG until I swapped out the old second gen small block for a LS2.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Rubber Conveyor Belt Air Dam
Old 12-19-2017, 11:08 PM   #6 (permalink)
Spaced out...
spacemanspif's Avatar
The New Focus - '07 Ford Focus ZX5
90 day: 32.44 mpg (US)
I have them in my focus and Mrs. Spif's 05 Legacy. She had a blow out about 2 weeks after buying the car and we replaced all 4. Seems to be a good tire, good wet traction, not boo noisy and seems to last on my Focus. Don't really have anything to compare them to but I am happy with them and would buy them again.
-Mike
2007 Ford Focus ZX5 - 91k - SGII, pending upper and lower grill bocks - auto trans
1987 Monte Carlo SS - 5.3/4L80E swap - 13.67 @ 106
2007 Ford Focus Estate - 230k - 33mpg - Retired 4/2018
1995 Saturn SL2 - 256K miles - 44mpg - Retired 9/2014
Cost to Operate Spreadsheet for "The New Focus"
