Old 03-16-2011, 06:04 PM   #71 (permalink)
Fizz - '06 Skoda Fabia Combi
90 day: 56.62 mpg (US)
First results on grille block on my 1.4TDi Fabia are encouraging - not had time for anything too rigorous yet but on my commute I can return 80-82mpg (imperial, on-board computer) where it was 75mpg before.
As far as the whole tank is concerned, its looking like my first 700miler- will know next week. (45litre tank).
So far so good.
Old 03-17-2011, 06:25 PM   #72 (permalink)
The PRC.
Ooh ooh 700 miles.
See the different between 1.4 and 1.9 (3cyl vs 4).
Old 03-24-2011, 10:18 AM   #73 (permalink)
Managed a 68mpg (imperial) tank, almost a 700 mile tank but not quite.
Old 03-24-2011, 10:44 AM   #74 (permalink)
The PRC.
What was your remaining range when you filled up ?
I chickened out at 35 miles remaining, or rather I surrendered to the Mrs pestering...
I got 53 for my last tank which is annoying as >50% of it was a couple of long trips both with an average of >65. 635 miles for me.
Also is your tank vented ?
Old 03-24-2011, 10:52 AM   #75 (permalink)
I had 50 miles remaining I think, wanted to fill with "cheap" fuel (less than £1.35 a litre). I've taken it to 15 miles once before- and I guess there is a safety factor built in!
It was "nearly 700 miles" IF I had run it dry
I don't think the tank is vented, I read about this on tdiclub. There's no button thingy to press like I had on a Citroen.
Need to find the time to do some rear wheel fairings now!
Old 03-24-2011, 10:57 AM   #76 (permalink)
The PRC.
What are your journeys like, mine are mostly suburban with a little bypass...
Old 03-24-2011, 12:44 PM   #77 (permalink)
Journeys - I'm lucky in that I don't have much start-stop urban driving.
I've looked at the overall fuel use on my commute, rather than mpg, and best choice of routes is a twisty B-road that is the shortest route, and includes a small town. Better even than steady 60mph on motorway over a much longer distance.
Just upgraded my grille block from coroplast to black foam-in-the-grille-gaps
Old 03-24-2011, 04:14 PM   #78 (permalink)
The PRC.
I have changed the start of my journey from a main road crawl to a backroad with a bad light at the end. Why ? Well on the crawl I spend a lot of time idling as it never really stops long enough to shut off. Now I can get to the end and wait in between greens with the engine off.
If I can work out a similar route for the homeward leg I may be able to get the figure up.
Old 03-24-2011, 04:15 PM   #79 (permalink)
The PRC.
Second post - what are your methods ?
Old 03-24-2011, 06:46 PM   #80 (permalink)
The Mistress - '88 Bmw 320i Touring SE
Team m8
Last 3: 27.17 mpg (US)
Germany Beadle - '91 Mercedes 300td (estate, N/A)
90 day: 24.63 mpg (US)
The Bloodylingo - '05 Citroen Berlingo Multispace Desire
90 day: 39.77 mpg (US)
Shanner Scaab - '03 Saab 9-5 estate Vector
90 day: 26.19 mpg (US)
Clio 182 - '05 Renault Clio RS 182 182
90 day: 31.73 mpg (US)
See, I'm confused re the "bad light"..
My commute takes me to a bad light within 1 mile of me setting off in the morning..Car is not up to temp so i've always wondered- engine OFF or on?
Nissan Versa SL Hatchback mod thread. stevet47 EcoModding Central 3 08-22-2011 04:28 PM
[Mod list discussion] Wiki up and running. Thread for suggestions to main mod list saand Forum News & Feedback 26 10-13-2010 06:19 PM
Rolla mod thread chuckm Aerodynamics 36 07-28-2009 08:08 PM
Looking for an "Aero Mod Materials" thread gascort Aerodynamics 7 05-06-2009 04:42 PM
Almighty's GP Mod Thread almightybmw EcoModding Central 1 11-07-2008 12:40 AM
