Old 07-24-2020, 02:13 PM   #1 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Assist a repair decision?
Power steering on my daughter's 2006 BMW 325i. I bought a PS Rack rebuild kit for the E90 (from Duralast).
Pictured are 4 O-rings in a row, from left to right: (1) old one, (2) new one, (3) old one, (4) new one. The #3 was the one that leaked and even in this not-great photo you can see that it is partly blown out.
Notice that the old ones appear to have larger diameter and are thinner in thickness. The old ones slid off easily and their inner diameter was basically the same as the fitting they were on. So, ...
Question: knowing all that, is it reasonable to assume the old ones have stretched and hardnened through years of heat cycles and that the new ones are appropriate and will work? In other words, I can stretch the new ones into place, yes? Or should I go to a supply shop I know and hope I can get in (COVID) and find a closer diameter/thickness match?
I am inexperienced with power steering systems. Thanks for all your assistance, friends!
Old 07-24-2020, 02:30 PM   #2 (permalink)
マット
M_a_t_t's Avatar
The Van - '95 Chevy Astro Cl V8 Swapped
Team Chevy
90 day: 7.84 mpg (US)
The new bike - '17 Kawasaki Versys X 300 abs
Motorcycle
90 day: 71.94 mpg (US)
The Mercury - '95 Mercury Tracer Trio
Team Ford
90 day: 34.35 mpg (US)
Toyota - '22 Toyota Corolla Hatchback
90 day: 40.11 mpg (US)
Most o-rings I've changed on P/S systems have to be stretched to fit. I'd assume the old ones were loose from age. If the OD is the same I think the new ones will be fine.
1973 Fiat 124 Special
1975 Honda Civic CVCC 4spd
1981 Kawasaki KZ750E
1981 Kawasaki KZ650 CSR
1983 Kawasaki KZ1100-A3
1986 Nissan 300zx Turbo 5 spd
1995 Chevy Astro RWD (current project)
1995 Mercury Tracer
2017 Kawasaki VersysX 300
2022 Corolla Hatchback 6MT
https://www.youtube.com/channel/UC6s...LulDUQ8HMj5VKA
The Following User Says Thank You to M_a_t_t For This Useful Post:
California98Civic (07-24-2020)
Old 07-24-2020, 03:52 PM   #3 (permalink)
Thalmaturge
CHONK - '18 Honda Clarity
What he said. Use the ones the part came with.
The Following User Says Thank You to samwichse For This Useful Post:
Old 07-24-2020, 04:38 PM   #4 (permalink)
Cyborg ECU
Great! Two trusted opinions. Thanks, guys.
