Old 10-22-2013, 11:43 PM   #1 (permalink)
Spaced out...
spacemanspif's Avatar
The New Focus - '07 Ford Focus ZX5
90 day: 32.44 mpg (US)
Attach pizza pan with 1 bolt?
I have a prototype pizza pan attached to 1 of my wheels. To attach it, I used the plastic lug covers that came stock on Saturns with a bolt through the back and a nut holding the pan onto the wheel. The reason for the bolts facing this way was because of how hard it was to get them to line up with a captive nut (drywall anchor) inside of the cover. I have attached a crappy pic of what I have done so far.
But I have a new idea. What if I got factory wheel covers and cut out the centers so that only the area around and within the nut covers was attached to the wheels. Then I could attach a nut (rivnut maybe) to the back of the cover center and then bolt the pan to the wheel with just 1 bolt.
My question is whether this has been attempted before and what the results were? Is 1 bolt enough to attach a pan to the wheels?
I'm thinking that the less fasteners I have to deal with, the more inclined I will be to pop off the covers and check tire pressure and also make any other job requiring wheel removal less tedious dealing with such a thing.
-Mike
2007 Ford Focus ZX5 - 91k - SGII, pending upper and lower grill bocks - auto trans
1987 Monte Carlo SS - 5.3/4L80E swap - 13.67 @ 106
2007 Ford Focus Estate - 230k - 33mpg - Retired 4/2018
1995 Saturn SL2 - 256K miles - 44mpg - Retired 9/2014
Cost to Operate Spreadsheet for "The New Focus"
Old 10-23-2013, 12:11 AM   #2 (permalink)
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
I thought about doing the same thing. I ended up doing this, instead:
http://ecomodder.com/forum/showthrea...vex-14958.html
http://ecomodder.com/forum/showthrea...ers-18495.html
The Following User Says Thank You to t vago For This Useful Post:
aerohead (10-23-2013)
Old 10-23-2013, 10:06 AM   #3 (permalink)
Spaced out...
Thanks for the links, t vago. My only question would be how well have they held up for you over the past years? I feel like frequent on/off cycles might hurt (crack) the t-shirt/resin causing a too frequent re-do.
-Mike
Old 10-23-2013, 11:06 AM   #4 (permalink)
MPGuino Supporter
t vago's Avatar
That's a valid concern. I cannot answer, because my covers haven't yet gone through a winter.
