Old 09-02-2013, 04:59 PM   #11 (permalink)
Jyden's Avatar
Enduro E-bike - '11 PowerPedals Enduro
90 day: 2236 mpg (US)
Jota - '14 Toyota Yaris Hybrid H1
90 day: 53.11 mpg (US)
Nuts! - but will follow with interest....
My Yaris Hybrid thread:
http://ecomodder.com/forum/showthrea...s-c-27995.html
Old 09-22-2013, 03:37 PM   #12 (permalink)
The PRC.
Any updates or plans on this ?
Old 09-23-2013, 12:29 PM   #13 (permalink)
Mechanical engineer
Vekke's Avatar
Siitin - '98 Seat Cordoba Vario
90 day: 58.56 mpg (US)
VW Lupo 3L --> 2L - '00 VolksWagen Lupo 3L
Diesel
90 day: 104.94 mpg (US)
A8 luxury fuel sipper - '97 Audi A8 1.2 TDI 6 speed manual
90 day: 64.64 mpg (US)
Audi A4B6 Avant Niistäjä - '02 Audi A4b6 1.9tdi 96kW 3L
90 day: 54.57 mpg (US)
Tourekki - '04 VW Touareg 2.5TDI R5 6 speed manual
90 day: 32.98 mpg (US)
A2 1.4TDI - '03 Audi A2 1.4 TDI
90 day: 45.68 mpg (US)
A2 1.4 LPG - '02 Audi A2 1.4 (75hp)
90 day: 24.67 mpg (US)
Project is officially started .
Weight of those 15" wheels 5.8 kg per piece.
Aerodynamic & rolling resistance, power & MPG calculator - EcoModder.com
Rough calculations of the project first with only diesel powertrain.
On lupo 3l you can reach 3 liters at 100 km/h speed with 1.2 TDI.
Lupo weights 950 kg with driver and A8 target weight 1500 kg = 36,7% difference in weight every 10% increase is 2-4% on highway --> max 14,7% higher fuel consumption
Lupo 3l CdA 0,29*2,0=0,58 Audi A8 modded 0,23*2,2=0,506 = A8 is 12,7% better so 12,7% less fuel consumption on highway speeds
That means I should try to keep the gear ratios pretty close to same as in my Lupo 3l gearbox. That is one reason behind that I will first test 195/65R15 tires. Other is weight savings and ofcourse the frontal area gets smaller.
https://www.linkedin.com/in/vesatiainen/
Vesa Tiainen innovation engineer and automotive enthusiast
Old 09-23-2013, 12:48 PM   #14 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Errr .... the online wheel shops that I checked, give 16" as the smallest wheels on the A8 (up to 10/2002 - and17" after that).
Are you sure the 15" will fit ?
Old 09-23-2013, 12:59 PM   #15 (permalink)
Mechanical engineer
Vekke's Avatar
Diesel
Sure they will fit but propably not with stock brakes. Lighter car needs smaller brakes...
Old 09-23-2013, 01:11 PM   #16 (permalink)
euromodder's Avatar
In that case ...
If you need any help with translations (Dutch / French / German) when searching for an A8 in Europe, just let me know.
Old 09-23-2013, 01:24 PM   #17 (permalink)
Mechanical engineer
Vekke's Avatar
Diesel
What I am looking for is:
- Audi A8 D2 2.5 TDI with manual transmission- must have
- Price between 1000-2500€ from europe. (Engine failure ones for 1000€)
- Miles does not matter as car is rebuild mostly.
- Outer body panels should be in mint condition so not crashed cars that arent repaired properly
- Learher interior
- Preferred color silver
Old 09-23-2013, 02:05 PM   #18 (permalink)
NightKnight
NachtRitter's Avatar
Helga - '00 Volkswagen Jetta TDI
Diesel
90 day: 54.39 mpg (US)
Mathilde - '99 Volkswagen Eurovan Camper
90 day: 16.87 mpg (US)
Wow! The car must be really light... there is nothing to it!
The Following User Says Thank You to NachtRitter For This Useful Post:
niky (09-23-2013)
Old 09-23-2013, 02:36 PM   #19 (permalink)
euromodder's Avatar
Though call ...
Autoscout
Old 09-23-2013, 02:36 PM   #20 (permalink)
HypermilerAX's Avatar
AX - '95 Citröen AX
307 - '04 Peugeot 307 SW
You will also gain with the better rolling resistance of 15" tires.
0950 kg / Cr 0,0079 / CdA 0,580 = 9,91 hp at 90 km/h
1500 kg / Cr 0,0066 / CdA 0,506 = 9,77 hp at 90 km/h
It can only be better at higher speed with better CdA.
Citroën AX 1.5 D 430.000 km
Peugeot 307 SW 2.0 HDI 136 195.000 km
1.2 tdi, audi a8, efficient, luxury sedan, tuneko
