Old 04-29-2010, 02:27 AM   #1 (permalink)
Custom User Title
Nut Wagon - '91 Civic Wagon DX
90 day: 52.46 mpg (US)
Honda Alternator with ELD
The 1991 Honda Civic Wagon I'm currently driving has an Electric Load Detector in the charging system.
Description here:
I monitored the voltage while driving and it works exactly as described 19 years later.
But I don't understand why it goes to full voltage above 65 km/h (40 MPH). I'm usually cruising at 50-60 MPH. Should I be thinking about tricking the alternator? I'm not yet sure what kind of signal the ECU is sending. Or should I be thinking about cutting the VSS signal in half? Any reason for the ECU to know the actual speed? The VSS is in the speedometer, driven by a cable, so no issues with displayed speed on the gauge.
Driving a 1991 Honda Civic Wagon and building a 1994 Geo Metro XFi.
Best tank with the Honda so far is 61.65 MPG.
The Following User Says Thank You to Gasoline Fumes For This Useful Post:
Piwoslaw (04-29-2010)
Old 04-29-2010, 04:59 AM   #2 (permalink)
aero guerrilla
Piwoslaw's Avatar
Svietlana - '05 307 SW
Diesel
90 day: 55.98 mpg (US)
A few new cars (BMW, 'eco' versions of certain European cars) have something similar - the alterator is cut off when not needed. I had no idea this was in production cars two decades ago.
There was a thread on automatically turning the alt on/off (can't find it right now), and there was a discussion on the conditions for turning the alt on. This should go there, maybe a crosslink?
EDIT: Found it! Preparing to crosslink...
Automatic alternator cut out/regen braking
Piwoslaw's Peugeot 307sw modding thread
Old 04-29-2010, 08:09 AM   #3 (permalink)
oldscoob - '87 wagon gl/dr
90 day: 47.06 mpg (US)
interesting.
I got one of those cars that has ecu and carb versions, years overlapped.
I bet it is in alot of ecu'd cars and not described, else, like a home pc it would burn. in the old days cars just simply fried thier rear quarters off.
at idle I have an alternator that refuses to be full below 750 rpm.On the same model car with injection, it went to 500 rpm idle too, like I am now, but no difference in volts to notice, lights stayed bright...
it may explain steellasting aslong as it has (I started attacking old steel when my car turned 20)
hmm.
I humor it the natural way and continue with a few more led bulbs...seems to be working.
interesting post. Subaru in contrast had connections never documented..always genius, but a gripe not knowing. That too is over 2 decades..like alot of japanese with complexities way ahead..
Project: Rebuilding an '01 Honda Insight as a nonhybrid Fabio Hybrids 155 05-01-2012 09:33 PM
Honda IACV explained TomO Off-Topic Tech 10 11-25-2011 12:59 PM
Honda Cub Makes a Comeback (Sort Of) SVOboy EcoModder Blog Discussion 2 04-28-2009 09:41 AM
Honda Insight Concept to Debut at Paris Int. Auto Show SVOboy EcoModder Blog Discussion 32 04-17-2009 10:45 AM
Honda Begins Use of Class 8 Hybrid Truck Q1000 Hybrids 0 03-11-2009 07:55 PM
