Old 07-22-2008, 11:37 PM   #1 (permalink)
The "S" - '00 Ford Escort SE
90 day: 40.8 mpg (US)
automatics in neutral?
Can u coast in neutral in an automatic?
I know the engine braking is slowing the car down.
I do it in my stick allthe time but those freakin auto trannies
mystify me.
Old 07-22-2008, 11:48 PM   #2 (permalink)
Should a read more
Sorry for this post ..looked and there was already one that covered this.
Old 07-23-2008, 12:02 AM   #3 (permalink)
bryn's Avatar
sputnik - '93 oldsmobile silhouette
90 day: 23.23 mpg (US)
home sweet home - '92 ford clubwagon E-350 xlt
very excelant - '92 honda civic vx
yup, you can neutral coast in an auto, i do it all the time.
be really careful about shifting in/out of neutral.
if you are going to EOC rember you can only restart your car in neutral or park.
make sure the neutral position is working properly somewhere that won't be a problem if you have to come to a complete stop.
shifting past neutral into reverse is bad, and very easy to do in my car. that said it is not as bad as in a manual shift. at 45mph it only skretched the tires for a split second. then stalled my engine. the tourqe converter alowed enough slip to coast till i could get it back into neutral and restart.
i destroyed my first volkswagon's manual trans. downshifting past first and going into reverse by accident first week with the car.
Old 07-23-2008, 12:07 AM   #4 (permalink)
bryn's Avatar
Originally Posted by BlackDeuceCoupe View Post
Yeah, you can, but...
Don't turn your motor off if you're going over... say, 20 MPH... or you'll burn up your tranny.
The pumps need to be working, and the oil circulating, even if you have it in neutral!
are you sure? i've never had a problem. maybe i don't own my cars long enough to see the effects.
Old 07-23-2008, 12:45 AM   #5 (permalink)
Mr. Blue Tape
azraelswrd's Avatar
AzxA - '06 Scion xA
90 day: 42.72 mpg (US)
Not all A-trannies are created equally. Advice I go by is if the manual says it can't be flat towed then neutral-engine off coasting is probably not a good idea. Otherwise, neutral-engine on coasting should be fine.
Results may vary, but if you don't know the towability then leave the engine on to be safe.
My 5 pillars of fuel efficiency:
  • driving style
  • aerodynamics
  • tires
  • weight reduction
  • engine maintenance
Old 07-23-2008, 12:53 AM   #6 (permalink)
bryn's Avatar
good idea.
i guess i will check my manual, before i do any more real damage.
Old 07-23-2008, 01:03 AM   #7 (permalink)
bryn's Avatar
BDC, thank you for your educated opinion as well.
as for me, i am getting a little bored with sputnik, i have had this fine mini van for almost a year, and i really dont need such a big car. i think i will keep living on the edge.
Automatics and Neutral? Gone4 Hypermiling / EcoDriver's Ed 19 10-09-2013 02:32 AM
Coasting in gear vs. neutral (fuel cut feature) WTFM8 Hypermiling / EcoDriver's Ed 28 05-29-2011 10:39 AM
Coasting in Neutral Vs. Coasting in Drive observation fonque Hypermiling / EcoDriver's Ed 21 07-17-2008 03:49 PM
Car Won't Start While Moving in Neutral Any Ideas? Axaday EcoModding Central 3 06-29-2008 11:26 PM
Experiment: EV coastdown in gear vs. neutral (in the ForkenSwift) MetroMPG Fossil Fuel Free 6 03-17-2008 10:12 AM
