Old 02-20-2019, 04:01 AM   #21 (permalink)
Lightest kerb weight is 780kg for a 3door with minimum equipment. But I'm not sure what this includes. In Denmark we use a standard of saying dry weight+120kg is kerb. However, EU standards says car with fluids etc +75kg = kerb. And all are listed as 800kg. Every car also comes with a full size spare tyre. 13-14kg.
The water pump is the same as many other cars with bigger engine the gesring of the pulley migjt be different. The alternator is 80amp I believe, so not far off bigger/golf class cars.
Waterpump is about 2500DKKR/400$/350€
I can post some figures later, in the meantime heres a 107 which basically is the same car, making 92hp. With intake/exhaust and a tune.
https://youtu.be/8Cc3xOsWyCY
Another I know of made 95hp with stock manifold/cat. The dyno might be optimistic, but it showed a difference in 12hp before/after.
The stock intake drop to 96-97kpa starting from 3500rpm. A filter will let it up to 100-101kpa. A little science will say 3-4hp depending on how low you can drop the temperature. A bolt on 42mm ID exhaust pipe will get i 6hp in peak rpm. I had this same exhaust, wich made the same difference ad stated in the video.
https://youtu.be/gVh3rjV5Spg
Old 02-20-2019, 11:14 PM   #22 (permalink)
Originally Posted by JohnnyJerry View Post
I did, but I figure that it'll be cheaper and easier to just make a cutout switch so the alternator freeruns when full throttle.
So the I'll get an electric water pump and freespin alternator, that should set of a few HP
I'd rather try to adapt some motorcycle-style stator instead. Assuming you won't need too much accessory drive, could eventually get rid of belts and pulleys entirely, plus having a reasonably constant electric power supply for the ECU, ignition and the electric water pump, among other essential components.
Old 02-21-2019, 03:19 AM   #23 (permalink)
The difference in quoting standards is the rub. But I expect the weight stated is to the same standards as the stated weight of the Mirage, due to the 0-100 times.
It's likely the KR-FE is more throttled and less optimized than the 4A from the factory (less headroom for modification on newer engines).
True, what matters is what the before and after numbers are, rather than the dyno readout (have had so many headaches over those over the years).
Mods aren't always additive. They give and take away, and sometimes once you've freed up the breathing/exhaust enough, extra modification will make less.
It's an interesting project, though... looking forward to seeing what numbers you can get, and what advantages in 0-100 and quarter mile times you can produce from this thing.
Old 02-21-2019, 11:54 AM   #24 (permalink)
Tje 1krfe is set for eco driving, which limit the airflow. So getting it to keep increasing or at least not drop drastically after 6500rpm will be a challenge.
On a note to the 0-100 times, I've had a little chat whit a racer from the Aquila Synergy league, which is based on the Aygo platform. The minimum weight with driver must always be 500kg, and 400kg without. They are 4.5 p/w ratio - he claims they do 0-100 in about 4s. So I can only be realistically optimistic.
Old 02-21-2019, 03:42 PM   #25 (permalink)
teoman's Avatar
A3 - '12 Audi A3
So drivers over 100 kg are at a disadvantage.
Copyright ©2000 - 2022, vBulletin Solutions Inc.
