Old 06-09-2010, 04:36 PM   #11 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
if you have 2 wires going to your injector(any injector, pick one), you have a 50/50 chance of getting it right on the first try
If you can, I would measure the ohmage of an unplugged injector. If it is 7 ohms or less there is a good chance it could be peak and hold, which still needs fixing on the guino.
dunno vss, would have to look at a schematic, or use the one from a $10 bike computer
Old 06-09-2010, 04:41 PM   #12 (permalink)
AeroModder's Avatar
Tank - '96 Ford Aspire 4 door
Team Ford
90 day: 46.75 mpg (US)
I checked the injector types, and they aren't peak and hold. However, I don't have a meter to test wires with. Electronics is my weak spot. It took a couple weeks to figure out how to hook up driving lights and a tach.
I have no idea what you're talking about with a bike computer. O_o
In Reason we Trust
Old 06-11-2010, 04:23 PM   #13 (permalink)
I have to start over?
Big inefficient truck - '94 Dodge Ram 2500
90 day: 12.1 mpg (US)
Honda Civic - '84 Honda Civic DX Hatchback
I received my MPGuino yesterday, and installed it today. It works great, so mad props to DCB.
As to your questions, Aeromodder, it does not come with a case. It is just a circuit board stuck to an LCD.
I can also say that I don't recommend using a reed switch for the speed sensor. It is a bit finiky, and 2 have gone out. I guess they are not intended to be used at high speeds
mpguino, prebuilt
'97 Chevy Cavalier Install and Questions maverick21016 OpenGauge / MPGuino FE computer 3 05-21-2010 01:33 PM
Mpguino prebuilt, know what you are buying dcb OpenGauge / MPGuino FE computer 0 10-24-2009 04:27 PM
MPGuino newbie questions mhopeng OpenGauge / MPGuino FE computer 2 06-28-2009 04:01 PM
A Few MPGuino Questions Axaday OpenGauge / MPGuino FE computer 12 07-23-2008 12:28 PM
Questions about mpguino mhmitszach OpenGauge / MPGuino FE computer 37 07-01-2008 07:38 AM
