04-09-2015, 11:56 AM
T-100 Road Warrior
BAT Industries Truck Mullet...
Concave truck topper...
Business Up Front, Aerodynamic in the Back | Restyling & Truck Accessories
Gallery
I find it interesting they are hitting the Ford F150 market as well. I noticed they state that they have a patent recorded. I wonder if bondo's patent is being infringed on or not.
Product Info
Dark Aero-The world's first aerodynamic single wheel boat tail!
The Following 4 Users Say Thank You to BamZipPow For This Useful Post:
04-09-2015, 01:04 PM
Spaced out...
I see how it will reduce the big vacuum on the truck but it goes against what we have all seen here with trucks laid against the "template"... hopefully aerohead will find this and chime in.
-Mike
2007 Ford Focus ZX5 - 91k - SGII, pending upper and lower grill bocks - auto trans
1987 Monte Carlo SS - 5.3/4L80E swap - 13.67 @ 106
2007 Ford Focus Estate - 230k - 33mpg - Retired 4/2018
1995 Saturn SL2 - 256K miles - 44mpg - Retired 9/2014
Cost to Operate Spreadsheet for "The New Focus"
The Following User Says Thank You to spacemanspif For This Useful Post:
04-09-2015, 02:26 PM
It likely helps, but sure doesn't look optimal.
Great marketing though: Truck Mullet!
04-09-2015, 02:28 PM
And if this is a case of patent infringement, maybe this is how Bondo strikes it rich.
Or at least gets some royalties.
The Following 3 Users Say Thank You to MetroMPG For This Useful Post:
04-09-2015, 02:29 PM
Ask the small company in Florida that has been collecting $99 per Prius from Toyota.
regards
mech
The Following 2 Users Say Thank You to user removed For This Useful Post:
04-09-2015, 04:21 PM
chime in
I just looked at it.It's way out ahead of nothing.It's 'different' enough to get its own design patent.
It will help with drag reduction,as the 1983 T-bird roof had an advantage over the Cougar.
Neither as good as Torino
Or PROBE-X
04-29-2015, 11:19 AM
Good grief! This looks like a much more professionally executed version of my old rubber apparition. No windows. Totally dependent on side mirrors for rear visibility. A bear to park. Comes flush to the tailgate. Tapers in at the sides.
See my avatar.
Differences: Mine was straight. His is concave.
Mine had no lid. His has one.
Mine was plywood and rubber matting. His is fiberglass.
But the concave shape, while not aerodynamically optimum is pleasing to the eye.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Rubber Conveyor Belt Air Dam
The Following User Says Thank You to Big Dave For This Useful Post:
04-29-2015, 01:46 PM
“I’ve got a couple wind tunnels in my basement that I do development with,” Holubar said.
Wait... WHAT?
The Following User Says Thank You to whatmaycome14 For This Useful Post:
04-29-2015, 01:56 PM
#9 (permalink)
This is hilarious ...
"when I was building the topper overnight, the back was concave instead of convex,” Holubar said. “And so I thought, ‘I’m not going to go through rebending all this plywood, so I’m just going to leave it as it is.’"
IOW, I discovered this magic thing by a lazy accident.
I'm not coasting, I'm shifting slowly.
The Following 2 Users Say Thank You to UFO For This Useful Post:
05-01-2015, 10:04 AM
#10 (permalink)
Yet another riff on Bondo's theme.
4" Slam
The Following 2 Users Say Thank You to Big Dave For This Useful Post:
