Old 05-10-2016, 11:52 AM   #51 (permalink)
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 Mercedes Benz 300SD
90 day: 23.23 mpg (US)
Gentoo320 - '04 Mercedes C320 4Matic
90 day: 22.44 mpg (US)
Because dynamic balancing is science, and not myth.
Yes it is a science. Note they mounted it to the rim and didn't just throw round weights in a deformable media like a tire.
The Following User Says Thank You to ConnClark For This Useful Post:
Fingie (12-16-2016)
Old 05-10-2016, 12:01 PM   #52 (permalink)
90 day: 43.3 mpg (US)
The same principles apply. Here ya go; a video where they "just throw round weights in a deformable media like a tire".
Old 05-10-2016, 12:16 PM   #53 (permalink)
DieselMiser
ConnClark's Avatar
And here is a video of them not working
Old 05-10-2016, 08:03 PM   #54 (permalink)
sendler's Avatar
90 day: 105.14 mpg (US)
90 day: 60.68 mpg (US)
90 day: 38.51 mpg (US)
PCX153 - '13 Honda PCX150
90 day: 104.48 mpg (US)
90 day: 80.94 mpg (US)
90 day: 72.57 mpg (US)
Balance beads can't be demonstrated on a tire balancer because the tire is not free to shake up and down as it would on the road. It is held by the massively rigid spindle completely without the normal hopping that it would get on the road which is the mechanism that forces the beads to move opposite of the hop as in the soda bottle demo I posted.
The Following 2 Users Say Thank You to sendler For This Useful Post:
freebeard (12-18-2016), redpoint5 (05-13-2016)
Old 12-13-2016, 11:26 AM   #55 (permalink)
Picked up a set of slightly used Hankook I-pikes on rims for my cobalt. Didn't have any lead on them so I assumed weren't balanced. Poured in 3 ounces of air soft pellets in each tires. $6 bottle was enough for 4 tires. Installed them Saturday. Car's as smooth as ever, tires louder the all seasons.
I think I'll switch to them cause they can't get stuck in the valve core or tire bead and of course cheaper. 12 ounces of Counteract is $13-14 if mail ordered.
Old 12-13-2016, 02:57 PM   #56 (permalink)
eco....something or other
wood hauler - '91 Ford F-250
Team Pontiac
90 day: 26.69 mpg (US)
Rav - '06 Toyota Rav4 Base
90 day: 26.52 mpg (US)
Yeah, the mass marketed beads are very expensive, and messy. That's why I went with airsoft bb's. The steel bb's I tried first worked for a while, but finally wore down to double ended thingys, not sure what to call them.
At low speed the bb's are against the tire, but still roll down a bit as they go uphill in the tire and then roll back down a bit as they go downhill, and they do this on every revolution of the tire, until you go fast enough to get them to stay in place.
1991 F-250:
4.9L, Mazda 5 speed, 4.10 10.25" rear
Old 12-13-2016, 10:14 PM   #57 (permalink)
Buggie - '01 Vw Beetle TDI Gls
Antifreeze.
Old 12-16-2016, 12:15 PM   #58 (permalink)
Phantom's Avatar
Blue Meanie - '02 Volkswagon Golf TDI
90 day: 48.52 mpg (US)
Wife's car - '05 WV Passat TDI
Rudy - '94 Chevy C2500
If you decide to run antifreeze please use propylene glycol such as Sierra Coolant that way it is nontoxic for when you get a flat.
I move at the speed of awesome.
"It's not rocket surgery!" -MetroMPG
Old 12-16-2016, 01:51 PM   #59 (permalink)
Volvo-driving MachYeen
Fingie's Avatar
Neo Volvo - '98 Volvo S70 10V
90 day: 24.98 mpg (US)
good idea with the BB's.
But a lot of tire balancers work on the principle that the tire balance is measured when the wheel slows down on the spindle.
For example, when you fiddle and spin something out of balance and it vibrates violently at a certain RPM before stopping.
and at the "braking speed" the bbs are already rolling
If you don't make any mistakes in your life,
life itself will be a f*ckup.
With Volvo to Valhalla and back!
Old 12-20-2016, 11:02 AM   #60 (permalink)
Great thread. I'm going to try 6 oz's of bbs per tire in my truck (245 75 r16). I live and work on dirt roads, so the outside of the tire will wear out before the inside. Bbs are cheap enough to put fresh ones in at evey tire change. Might look into a hf tire changer too. Proper balance will help make an aging front end last longer imo.
