Old 06-19-2012, 11:36 AM   #11 (permalink)
Enthusiastic EcoModder
Gnatmobile - '96 Geo Metro LSI
90 day: 44.68 mpg (US)
theRAV - '01 Toyota RAV4 NV
90 day: 21.07 mpg (US)
ACCELICA - '95 Toyota Celica GT Convertible
Last 3: 23.46 mpg (US)
The Van - '05 Chevrolet Uplander LS LWB
90 day: 21.04 mpg (US)
I simply covered the whole bottom, trimming only a small section where the headers came in contact with the coroplast. The result was coroplast melting in 2 other places where the exhaust heat was too much but no biggie, I just had to smell it for a day and then it sorta self trimmed itself. My plan is to buy aluminum flashing (basically a big roll of sheet aluminum that's very inexpensive and can be cut with scissors - hardware stores in the roofing section) and rivet it in as patches for the open sections. I haven't gotten to doing this part for a reeeaaallly long time and one bummer is that in the trimmed sections the heat has caused the coroplast to curl a way from the heat a little bit and made my belly pan a bit less smooth. The flashing will fix this whenever I get to it.
"You too can get 50 Miles per Gallon, all it will cost is your self-respect."
Old 06-22-2012, 10:20 AM   #12 (permalink)
Just use the aluminum foil tape. Like duct tape in application, its thin foil will dissipate any heat from hot spots better than a thicker material.
