Old 04-12-2014, 06:42 PM   #1 (permalink)
WagonyGuy's Avatar
Lil White Narwhale - '91 Honda Civic Wagon
90 day: 37.2 mpg (US)
White Fit - '13 Honda Fit Sport
90 day: 38.89 mpg (US)
Best height for airdam
Is there a "right" height for an air dam? I am going to put one, plus side skirts, on my Honda Fit soon. But what is the optimal height? The car has about 7 inches of clearance on the front and sides.
Old 04-12-2014, 07:08 PM   #2 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
practically, the best 'height' is where it wont scrap.
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
Old 04-12-2014, 07:27 PM   #3 (permalink)
nemo's Avatar
Chief - '06 Pontiac Grand Prix
90 day: 26.7 mpg (US)
SF1 - '12 Ford Fiesta S
90 day: 30.95 mpg (US)
There is no one height. The idea behind the air dam is to reduce turbulent airflow under the car and redirect it to the sides where it hopefully less turbulent. Many use a measurement that coincides with the low hanging parts. On my GP thats about 6".
In this picture you can see the subframe in the background my air dam is 1/4 inch below that. This configuration on this car vary rarely scrapes because it is further back. If it was forward of this location it would drag more often. Same with the side the wheel base will determine how low you want go.
Many here have done lawn edging air dams. Do a site search there is quite a bit of information on air dams and splitters maybe even some for a Fit. You might also want to look in to belly pans.
Old 04-12-2014, 10:10 PM   #4 (permalink)
Best height for an air dam is as low as you can go.
At some point friction from the air dam scraping on the ground will over come aerodynamic gains, until the air dam wears away.
Old 04-13-2014, 06:44 PM   #5 (permalink)
Lots of Questions
Motor-Rolla - '01 Toyota Corolla LE
90 day: 28.3 mpg (US)
Gaia - '99 Toyota 4Runner SR5 Highlander
90 day: 19.78 mpg (US)
Gaia - Round 2 - '99 Toyota 4runner SR5 Highlander
90 day: 17.92 mpg (US)
I thought the best height was whatever the lowest hanging item on the car is. Any more than that and you are adding surface area to the car.
If that is the case, then moving things or tucking them up higher into the belly would be beneficial, no?
Don't forget to like our Facebook page!
Best EM Quotes:
It has been said, that if you peel the duct tape back on Earth's equator, you'll find that the two hemispheres are held together with J B Weld.
Originally Posted by Dan9 View Post
subscribed with a soda.
If you're burning,and someone throws gasoline on you,there will be a localized cooling effect, but you're still on fire.
Old 04-14-2014, 06:50 AM   #6 (permalink)
GTR
Red VX - '93 Honda Civic VX
Teal VX - '94 Honda Civic VX
Godzilla - '09 Nissan GTR Premium
There is a ton of info in this thread about airdam height.
http://ecomodder.com/forum/showthrea...amics-312.html
Old 04-14-2014, 07:59 PM   #7 (permalink)
WagonyGuy's Avatar
Thanks for the link. 40+ pages is a lot to read. I'm going to have to mull it over and do some more measurements. Putting $150+ of parts is going to have to be sure to give me a decent ROI. The rubber belt at Tractor Supply is kinda pricey.
Old 04-15-2014, 01:20 AM   #8 (permalink)
I think that the lawn edging can look good if done right. Let's see if I do better the second time!
Old 04-15-2014, 01:27 AM   #9 (permalink)
GTR
seems best aeromods for return on investment are airdam, underbelly covers, wheel covers, and kammback or boattail. airdam and underbelly can be coroplast it seems, not too much $. Lawn edging is cheap, too, as Xist mentioned.
Old 04-15-2014, 02:38 PM   #10 (permalink)
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 Mercedes Benz 300SD
90 day: 23.23 mpg (US)
Gentoo320 - '04 Mercedes C320 4Matic
90 day: 22.44 mpg (US)
Passenger Car Front Air - Dam Design Based on Aerodynamic and Fuel Economy Simulations
"To reduce the drag a lot of aero-parts are used these days such as air-dam, skirts, spoiler, undercover, dams etc. However the design of these aero-parts must be optimized to get the desired result as their addition alone does not guarantee improvement in performance."
