Old 04-28-2010, 06:30 AM   #11 (permalink)
comptiger5000's Avatar
RaceJeep - '98 Jeep Grand Cherokee (ZJ) 5.9 Limited
90 day: 13.62 mpg (US)
I agree that newer OEM cats are much better flowing than they used to be. Also, BGD is right about the header thing. If you're going to put in a high flow cat, it's a good time to re-do the exhaust. If you can get long enough headers that aren't too huge, they won't hurt your low end torque. Plus, then you can wrap them, and maybe even the Y pipe, so the cat gets hot faster, and absorbs more heat, allowing a larger, higher flowing cat to work effectively.
Call me crazy, but I actually try for mpg with this Jeep:
Typical driving: Back in Rochester for school, driving is 60 - 70% city
Old 04-28-2010, 02:10 PM   #12 (permalink)
Phantom's Avatar
Blue Meanie - '02 Volkswagon Golf TDI
90 day: 48.52 mpg (US)
Wife's car - '05 WV Passat TDI
Rudy - '94 Chevy C2500
You are putting on ceramic headers so that will contain more of the heat in the pipe and push it to the cat. I would probably just go with a cat from the original supplier and find one that is similar in the original dimensions but has a larger inlet and matching outlet.
I move at the speed of awesome.
"It's not rocket surgery!" -MetroMPG
Double Catalytic converter requirements? msmnick EcoModding Central 7 01-30-2010 11:41 PM
Catalytic Converter Bypass Valve zman EcoModding Central 17 01-11-2010 01:18 PM
Has anyone tried making/using a catalytic converter warmer? twolostminds EcoModding Central 79 01-09-2010 05:56 PM
Catalytic converter or oxygen sensor? rick390 Off-Topic Tech 8 12-09-2009 10:11 PM
