Old 05-26-2020, 03:25 PM   #141 (permalink)
90 day: 54.57 mpg (US)
90 day: 64.86 mpg (US)
And I wouldn't say the MPG gains from this project are small. It's all relative, I suppose.
And now you can tell everyone you drive a plug-in hybrid.
Old 11-07-2022, 02:12 PM   #142 (permalink)
500 Mile Metro Traveler
'89 Dakota LB - blue - '89 Dodge Dakota V6 LE
90 day: 19.8 mpg (US)
'17 Fiat 124 - SunFiat - '17 Fiat 124 Spider Classica
90 day: 30.51 mpg (US)
'89 Metro - The Egg - '89 Geo Metro Base
90 day: 50.71 mpg (US)
'94 Alto - The Box - '94 Suzuki Alto Ce-L
90 day: 39.5 mpg (US)
This thread has inspired me to present another take on the alternator delete idea...
How about a solar hybrid with passive electric propulsion?
Instead of removing the alternator, convert it into an electric motor that can be used to provide 2-5 hp of assist? Plenty of DIY you tube videos on this topic.
For battery power use lithium batteries that can be both charged from a roof mounted solar panel and/or plugging in to the grid via home solar.
For starting the car (which lithium batteries do not like) add supercapacitors to handle the instantaneous amperage spikes.
By theory, you could effectively double that mpg improvement to 20 percent or more since the load on the motor for a given task will be dropped
significantly. Free HP.
I am in the middle of this DIY solar project and hopefully can come back with some noteworthy positive results.
Old 11-07-2022, 02:45 PM   #143 (permalink)
I just watched one of my favorite presenters 46 minutes after it went up:
I'd considered the EcoFlo Delta previously, but he does a good job, teardown and all. My thought when I watched it was that if I put one in my Superbeetle, I could have an ICE vehicle-to-microgrid situation.
The older I get, the better I was -- John Fogerty on Joe Rogan
Old 11-07-2022, 02:51 PM   #144 (permalink)
Yes it would be a micro grid, but horribly inefficient imho. 1gal fuel turned into mostly heat, but it would be handy for really long periods of power outages to keep the fridge cold.
Old 11-07-2022, 02:57 PM   #145 (permalink)
90 day: 33.31 mpg (US)
90 day: 62.22 mpg (US)
We're into "fridge" weather here now. If power goes out, just wheel the fridge outside.
I do like that I can keep beer in the garage and it's the right temp.
Old 11-07-2022, 03:02 PM   #146 (permalink)
If I put my homebrew into the garage tonight, it would maybe freeze and explode the bottle
Old 11-07-2022, 03:22 PM   #147 (permalink)
I'm not sure if my garage ever freezes. It should if the insulation is good enough in the house and door. It gets mighty cold, but I don't recall it freezing.
Old 11-07-2022, 03:25 PM   #148 (permalink)
That's just one scenario. The device is the beating heart of a sytem with solar, AC and 12V inputs and three outputs (AC, USB-A and -C).
Solar panels go on the carport, not the vehicle.
Old 11-08-2022, 10:00 AM   #149 (permalink)
Sport Utility Prius - '10 Toyota Prius II
90 day: 52.98 mpg (US)
300k Sequoia 4WD - '01 Toyota Sequoia Limited 4wd
90 day: 20.19 mpg (US)
I'm over here racing to finish up my projects down here while its still 70s outside. lol
This weekend we are supposed to get to 40s and below finally :/
"I feel like the bad decisions come into play when you trade too much of your time for money paying for things you can't really afford."
