Old 01-08-2012, 04:54 PM   #1 (permalink)
Better fuel efficiency and less wear
Hello guys and gals.
I have been reading threads here for quite some time and I really like how you guys take existing tech,put a slight spin on an idea and realize some promising results. Auto manufacturers really should pay attention.
Anyways I am not an Eco-moder however I do want to consume less fuel in my carb'd gas equipment at work as well as save fuel in my vehicles.
I have read quite a bit about acetone mixed in the fuel. I have been adding roughly an ounce per 10 liters of fuel and my compressor at work lasts about an hour longer since. Now is there maybe a ratio for max fuel efficiency and has anyone tested it enough to know the ratio.
2 stroke oil also seems according to my mechanic to lessen wear in the cylinder. Now does anyone have any experience with this. I have been using 2 ounces per 10 liters in the same fuel for my gas equipment at work and like I posted,less fuel consumption.
So now to my vehicles and fuel injection. Is there a ratio to use that is o2 sensor safe. I have unlimited amsoil dominator 2 stroke oil. It's ashless and supposed to burn ultra clean. So I guess I am asking if anyone has any experience with any of these ideas.
I appreciate any responses. If you guys have any ideas I am all ears. Now I don't want to get inside the motors and make adjustments. I just want to know if any on the shelf products can help in this regard.
I know going thinner oil is supposed to help fuel economy however my motors are tortured and thinner isn't an option.
Thank you
Old 01-08-2012, 06:17 PM   #2 (permalink)
...beats walking...
...sorry, but burning acetone does not yield better fuel economy.
Old 01-09-2012, 09:58 AM   #3 (permalink)
Really. Tell that to my generator and compressor. The run times per tank seem to be getting longer. Compressor used to last 6 hours. It now runs 7 on the same fuel with only acetone added. And my generator would last 14 hours. Now it goes 2 full 8 hour days before needing re-fueling.
Thanks for your input.
Old 01-09-2012, 01:26 PM   #4 (permalink)
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 Mercedes Benz 300SD
90 day: 23.23 mpg (US)
Gentoo320 - '04 Mercedes C320 4Matic
90 day: 22.44 mpg (US)
Acetone can act as a detergent so it might have cleaned your carburetor and fuel system which can improve fuel economy. Any gains beyond that aren't possible.
Old 01-09-2012, 02:40 PM   #5 (permalink)
Eco-ventor
jakobnev's Avatar
Princess - '92 Mazda MX-3 GS
House of Tudor
Team Mazda
90 day: 53.54 mpg (US)
Shirubāarō (*´ω`*) - '05 Toyota Prius Executive
90 day: 54.88 mpg (US)
Blue Thunder - '20 Hyundai IONIQ Trend PHEV
Plug-in Hybrids
90 day: 144.39 mpg (US)
Send a message via MSN to jakobnev
Originally Posted by Everett View Post
..seem..
Have you done any systematic measurements and made a sincere effort to exclude other factors? (Including random variance)
Old 01-09-2012, 02:56 PM   #6 (permalink)
UFO
UFO's Avatar
Colorado - '17 Chevrolet Colorado 4x4 LT
90 day: 23.07 mpg (US)
The anecdotes on this topic are numerous, so let me add one. Some have tried to validate it with an ABA type test, so when the acetone was added, there was a slight mpg increase, but when the acetone was removed (for the second baseline), the mpg gain did not track. At best, there is a cleaning effect, but most likely it's a placebo.
I'm not coasting, I'm shifting slowly.
Old 01-09-2012, 05:22 PM   #7 (permalink)
Black Knight - '94 Toyota Corolla
90 day: 58.53 mpg (US)
at least your system is clean.
Old 01-09-2012, 06:00 PM   #8 (permalink)
DieselMiser
ConnClark's Avatar
And now for something completely different
