Old 01-26-2011, 08:52 PM   #81 (permalink)
NHRABill's Avatar
Tahoe - '95 Chevrolet Tahoe LT
90 day: 13.22 mpg (US)
SRX - '04 Cadillac SRX AWD
XL - '05 Harley Davidson Sportster XL
90 day: 49.97 mpg (US)
Alero - '02 Oldsmobile Alero GLS
Corvette - '75 Chevrolet Corvette Stingray
Figuring your gear ratio is easy.
Jack the complete rear axle off the ground
Mark a tire with a line
Mark the drive shaft with a line
have one person turn the tire a complete revolution
while the other person counts how many times the drive shaft turns.
for example if you follow the above instructions and your 1 tire revolution may = 4.10 turns on the drive shaft and there is your answer.
a 3.73 rear gear is a nice truck gear for people that haul with a 3 speed trans. Swapping the rear gear is not difficult at least the ones that I have done.
The ford 9" is by far the easiest of all rear gear swaps but I am sure you have the big boy rear on those heavy duty trucks. I have swapped many ring and pinion gears on GM cars 10 bolt 12 bolt cars as well as corvette centers. from the 2.73 to a 5.13 gear it is a CHEAP and easy mod to do yourself or get done for you. Changing the rear gear means a WORLD of difference in engine RPMs do your math tons of online calculators out there check out Hot rod sites for one If you have a truck with decent power and torque you should have no problem if you are an average driver with a weekly load in a non mountain area
2012 Chevrolet Traverse *active*
2002 Oldsmobile Alero GLS *active*
2002 S10 2wd p/u 139,000mi. *active*
1975 Corvette Stingray *active*
1994 Camaro Z28 Convertible 149k *Sold 2013*
1998 Blazer ZR2 189k *Sold 2012*
1995 Tahoe LT 250k *Sold 2011*
Old 01-28-2011, 10:05 PM   #82 (permalink)
90 day: 19.36 mpg (US)
AUTOMETER Diesel Tach Install Schematic
Old 01-28-2011, 10:12 PM   #83 (permalink)
JacobAziza's Avatar
Big Orange Work Truck - '83 Ford F-250
90 day: 27.54 mpg (US)
Jessica's - '04 Toyota Matrix
90 day: 41.21 mpg (US)
Ninjette - '01 Kawasaki Ninja EX250R
Originally Posted by slowmover View Post
Oh man!!
I really appreciate the effort.
Won't work for me though - I removed my alternator months ago, in pursuit of better mileage!
I tried making one from a bike cyclometer and a permanent magnet, but had a lot of trouble getting the magnet to not fly off at normal speed, and getting the bracket to align and stay aligned, and eventually gave up.
Originally Posted by Piwoslaw View Post
A few months ago I returned home just as my neighbor pulled into his driveway. It was cold (around freezing) with some rain and sleet, and he yells to me: You rode your bike? In this weather?!?
So the other day we both returned home at the same time again, only now the weather is warm, sunny, with no wind. And I yell to him: You took the car? In this weather?!?
Old 01-28-2011, 10:16 PM   #84 (permalink)
Then look at TINY TACH.
Old 01-29-2011, 05:29 AM   #85 (permalink)
reenapayel
Guest
Posts: n/a
Better mileage than average new passenger vehicle in 2.5ton commercial truck!
Thanks for the correction. I didn't measure the frontal area with any great accuracy, just a tape measure and some quick estimates so I would not be surprised if it is off. I've played with measuring Cd and Crr a bit more since originally posting this instructable and other experimenters have picked apart and tweaked the spreadsheet for their own uses so I'm 99.9% confident there is not a mistake in the spreadsheet.
Old 01-29-2011, 09:18 AM   #86 (permalink)
JacobAziza's Avatar
Now that is interesting. Albeit expensive. I think I'll try my method again before I spend so much.
Old 03-25-2011, 11:28 PM   #87 (permalink)
update?
Been drive my 87 F250 oh boy it worst on economy. Only got 16-17 mpg most times. WORST 11 that when it have leak and idle for 2 hours due snowstorm here. It been 20-30oF here.
It seem it smoke black on accelerator or under load. Suspect PO turn up the injector pump.
Temp Gauge never get up it barely creep to pass BIG white mark then drop. It got up to little closer to N when it was 70oF. Going to remove fan clutch and belt for ac compressor.
Could you tell best tip you done to truck and improve much economy.
Old 03-27-2011, 11:40 AM   #88 (permalink)
comptiger5000's Avatar
RaceJeep - '98 Jeep Grand Cherokee (ZJ) 5.9 Limited
90 day: 13.62 mpg (US)
Milwaukee - As far as the not warming up, try replacing the thermostat. Also make sure the fan clutch isn't locked up, or convert it to an electric fan. I wouldn't drive with no fan, as if you ever get stuck in traffic, you're screwed.
Call me crazy, but I actually try for mpg with this Jeep:
Typical driving: Back in Rochester for school, driving is 60 - 70% city
Old 03-27-2011, 07:32 PM   #89 (permalink)
JacobAziza's Avatar
Before I removed the clutch fan (and replaced it with electric) and added the grill block, mine never got beyond the lowest part of the "L" of the L------H temperature gauge either.
You asked me the same question before. I still say driving slower made the single biggest difference.
Looking back at my fuel mileage log on EM over the past 2 years, no one thing stands out as making a hugely dramatic difference.
1983 Ford F-250 Gas Mileage (Big Orange Work Truck) - EcoModder.com
Its been gradual incremental improvements from each step, with the exception of my first tank after reading the article on Wayne Gerdes in which I first learned of the concept of "hypermiling".
In terms of combinations of things, did removing all the engine belts (fan, alternator, power steering, and vacuum pump) help more or less than the aero changes (grill block, underbelly panels, wheel well skirts, and tilted tonneau)? I have no idea, as they were all incorporated together haphazardly as my ecomodding hobby grew.
All I know is I started out getting the same mileage as you are getting now, and 2 years later I am averaging just under 30mpg for about a 4 month span.
Old 03-27-2011, 09:24 PM   #90 (permalink)
live, breath, Isuzu-Ds
trooper Tdiesel's Avatar
puddle jumper - '93 Suzuki sidekick base model
energizer bunny - '86 isuzu trooper base model
Clifford the big red dog - '84 GM S-10 durango
are 1989 7.3L N\A, 1ton, 4door, 4wd, 4.11s
with the pile of poo E4OD auto trans.
pulled 21.9 mpg once years ago, in yellow-stone park at 45mph.
17/19 at 55 with stop lights is more common.
its right about 8,500lbs full of fuel (65 gal) and two people.
in comparison i must say 28+mpg is quite impressive for a F250
the closest ive ever heard of to that number was a 2wd L\B extra cab with the 3.55 and a O\D 4sp. pulling 24 or so at around 55/60
he ordered it from the factory to get that combo, he wanted a 1ton with out dully rear tires and ordering it was the only way to get a ford 1ton with out being a dully in the 6.9L years.
do to this, the truck says F250 on the side but its springs, axils, trans ECT are all 1ton spec
1 86 T\D trooper with rare GEN 3 rods TRANS FIXED NOW DD
1 86 4WD 5sp pup is 2.3L gas, but plan on 2.2L diesel repower
1 91 trop, long term plan is a group buy of imported Isuzu 4JB1-T 2.8L I-4 engines, hoping to get price down to 2K not 3K plus
1993 sidekick my MPG toy, epa rating 26.
i get 29/31 with stock drive train.
EcoModding for Beginners: Getting great gas mileage. SVOboy EcoModding Central 55 08-20-2012 11:34 PM
Registering a car based reverse trike in CA Carwhisperer EcoModding Central 58 07-10-2011 07:12 AM
Flashing yellow light skyl4rk EcoModding Central 5 08-01-2010 01:57 PM
Honda Begins Use of Class 8 Hybrid Truck Q1000 Hybrids 0 03-11-2009 07:55 PM
Efficiency from an inefficient vehicle? hillman88 Introductions 3 11-16-2008 05:30 PM
