View Poll Results: More Dangerous: Drafting or Tire Over-Inflation?
Drafting 31 96.88%
Tire Over-Inflation 1 3.13%
Voters: 32. You may not vote on this poll
Old 04-02-2008, 04:01 PM   #1 (permalink)
Depends on the Day
RH77's Avatar
Teggy - '98 Acura Integra LS
Sports Cars
90 day: 32.74 mpg (US)
IMA - '10 Honda Insight EX
90 day: 34.76 mpg (US)
Tessie - '06 Acura TSX Base
90 day: 28.2 mpg (US)
More dangerous: Drafting or Tire Overinflation
I wish to make a general observation:
When there mention of drafting, I don't see the knee-jerk reaction of caution there is to tire over-inflation.
Which do you feel is more dangerous?
Discussion to follow as the poll numbers come in...
RH77
“If we knew what we were doing, it wouldn't be called research” ― Albert Einstein
_
_
Old 04-02-2008, 04:06 PM   #2 (permalink)
MechE
The Miata - '01 Mazda MX-5 Miata
Drafting
The quick and not so obvious reason is complacency and comfort. People drive really close as it is, so their comfort level is okay... Slowly, getting closer isn't a thing to be worried about - and on long drives, your mind may not give as much attention as necessary...
Cars have not created a new problem. They merely made more urgent the necessity to solve existing ones.
Old 04-02-2008, 04:15 PM   #3 (permalink)
Who
UnderModded
Pablo - '07 Hyundai Santa Fe AWD
90 day: 23.62 mpg (US)
Driving or cycling?
Old 04-02-2008, 04:17 PM   #4 (permalink)
roflwaffle's Avatar
Camryaro - '92 Toyota Camry LE V6
90 day: 31.12 mpg (US)
Red - '00 Honda Insight
Prius - '05 Toyota Prius
3 - '18 Tesla Model 3
90 day: 152.47 mpg (US)
Considering that it'd be pretty hard to dangerously over-inflate a tire while driving efficiently, based on the sidewall ratings, and people drive dangerously close to each other already, I'm going with drafting too. Like most risky behavior, it isn't a problem until there is a problem, and then things go to **** quick.
Old 04-02-2008, 04:33 PM   #5 (permalink)
I believe both can be done safely, but drafting is definitly the more hazardous. Drafting can provide benefits pretty far away from the back of a semi.
Old 04-02-2008, 05:19 PM   #6 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
My tires are at 120 psi...on by bike,
But I said drafting, since I've never seen anything dangerous with over-inflation.
Old 04-02-2008, 05:33 PM   #7 (permalink)
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
Rear ending someone is a very common auto accident, although it's true that most rear endings happen at stop lights, multi car pile ups hurt and kill alot of people.
Old 04-02-2008, 05:41 PM   #8 (permalink)
Weight Reduction
ankit's Avatar
4x4 - '06 Nissan Altima 2.5 Special Edition
90 day: 29.04 mpg (US)
Mom's Van - '99 Plymouth Voyager SE
90 day: 25.62 mpg (US)
Send a message via AIM to ankit
Like this...
Notice the perfect paint on the bumper, I put a lot of care into the looks of my car and then someone hits me.
I do both at in moderation. Tires at max but not above, 44 psi. Draft at a comfortable distance behind semi's and make sure there is an exit route (open left or right lane to switch to incase of emergency), since mythbusters showed a FE gain at a far distance.
Drafting is definitely more dangerous and should only be done in the right conditions IMO. Good brakes, visablilty, exit route, not putting anyone in danger for FE.
Live Simply So Others Can Simply Live
-Ed Begley Jr.
Old 04-02-2008, 09:36 PM   #9 (permalink)
ECO-Evolution
Lazarus's Avatar
Iron Horse (retired) - '97 Iron horse Intrepid
Ninja - '08 Kawasaki 250R
90 day: 76.23 mpg (US)
I've had blowouts and none of them have been a big deal. "Pshh! flub flub flub flub. Oh, what's that?" Pull over, maybe curse a little bit, put the spare on, go. I'd much rather do that than rear-end a semi or have them kick something up.
I'm with you on this one.
"Judge a person by their questions rather than their answers."
Old 04-03-2008, 01:06 AM   #10 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
RH77 -
Wow, my vote makes it 22 to 0. I do the "far away draft" and I do the "close cut-in fall back draft". That is to say, I hit the turn signal as a car is passing me, cut right in behind, and start falling back. Soooooo, I never really do a tailgate draft. I am almost always following the 3-second rule, sometimes 4-seconds.
I've studied the tire-over inflation thing to the point where I have no worries. I am conservative in my PSI, but I "don't fear the pressure".
CarloSW2
American Solar Energy Society
Tire pressure (of winter tires) tasdrouille General Efficiency Discussion 20 08-12-2009 01:38 AM
Unreliable results measuring MPG / overinflation valve stem failure Cd EcoModding Central 9 03-31-2008 02:26 AM
SuperMID calibration methods ? / overinflation valve stem failure Cd EcoModding Central 8 03-30-2008 09:15 PM
Drafting off center? dissimilation Hypermiling / EcoDriver's Ed 5 12-29-2007 01:48 PM
Article: Green push hits tire makers MetroMPG General Efficiency Discussion 0 12-16-2007 07:14 PM
