Old 02-24-2009, 11:57 AM   #1 (permalink)
MPG...what?
Terkle - '97 Toyota Tercel Whitehawk
90 day: 40.91 mpg (US)
Bubble - '10 Toyota Yaris base
90 day: 41.88 mpg (US)
Deva - '13 Chevrolet Spark LS
90 day: 39.82 mpg (US)
Malibu5 - '82 Chevrolet Malibu Classic
90 day: 17.61 mpg (US)
Highlander - '06 Toyota Highlander Limited
Send a message via AIM to malibuguy
rear wheel skirts...
for the people who have done them, how much of a gain is there? I'm pondering making some for my tercel...
-Greg...the exhaust freak.
-06 Highlander 3.3awd
-10 Yaris sedan
-97 Tercel, 1NZfe swapped
-96 Tercel
-82 Malibu 1UZfe swapped
-19 Fit (wifey ride)
www.pipedreamsfab.com
Old 02-24-2009, 05:37 PM   #2 (permalink)
I have no fe instrumentation... only calc fe tank-to-tank... had skirts and other aeromods on too for quite a while. Couldn't detect change that could be attributed to aeromods.
Not saying it's impossible. Saying results are so small- if any- you'd have a hard time noticing it. And an even harder time proving it.
Do it if it makes you feel good, or are curious. Just don't expect any miracles.
aerohead (07-22-2017)
Old 02-24-2009, 07:30 PM   #3 (permalink)
They looks like they're good for around a 3% increase.
Testing grille blocking & wheel skirts: +5.7% improvement - MetroMPG.com
http://ecomodder.com/forum/showthrea...-camry-84.html
Old 02-24-2009, 11:15 PM   #4 (permalink)
Hi,
On my xA, the front grill blocks and fog light covers added ~10-12%, and the smooth wheel covers added ~6%, and yes the rear wheel skirts are ~2 to maybe 3%.
Old 02-25-2009, 07:38 AM   #5 (permalink)
MPG...what?
so it looks like its minor...i'll worry about doing a partial under tray first...that should make a bigger difference
i also need to smooth out the rear from the rear axle beam to the bumper
-10 Yaris sedan
-96 Tercel
Old 02-25-2009, 06:53 PM   #6 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
It depends (TM)...
If the rear wheels are right at the back corner (less bodywork aft for detached flow to reattach on), I think skirts will have a bigger impact.
Also depends on the size of the vehicle's tire/wheel arch gap, the rim design (unless you've got smoothies on), wheel offset...
I agree with Frank: for a normal car, you likely won't be able to see the results over the usual tank-to-tank noise.
Also see:
Old 02-25-2009, 07:09 PM   #7 (permalink)
OurInsight - '06 Honda Insight
I have skirts on my Echo and Scangauge instrumentation. I made before and after, two-way tests on a windless day. It looks to me from the scangauge data that the improvement was about 1.4%, near as I could tell. Might be worth more on a Metro, as someone above mentioned. I wouldn't be able to see that small change on a tank-to-tank basis.
The Following User Says Thank You to jime57 For This Useful Post:
Old 02-25-2009, 07:27 PM   #8 (permalink)
As for the undertray it seems as though the amount of benefit is dependent upon how high your car is and how rough the underbody is. If your car sits low to the ground already then the undertray may not be that effective. However, the higher it sits and the rougher the underside then it may have more of an effect. That's what I gleaned from reading a VERY long thread on the subject. If I misinterpreted it then by all means let me (and everyone else) know.
PS When doing your aeromods try to do the ABA testing so you have before and after mod baselines for comparisons. Thanks.
The Following User Says Thank You to Daveedo For This Useful Post:
Nautilus (07-18-2017)
Old 02-25-2009, 07:40 PM   #9 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
One good thing about the under tray vs other mods, even if it's not that great of an aero-improvement, it helps to keep your engine bay clean, which is nice for when you're working in there.
Also, a clean engine could be running more efficiently than a dirty one. The grease and grime kind of holds the heat into the engine, in the wrong places, IMO. I prefer to keep it clean. A bottle of simple green and some water will get you a long way in making the underhood area a little more tolerable to mess with.
Old 02-25-2009, 09:42 PM   #10 (permalink)
Not sure I'd spray Simple Green in the engine bay. It softens some polymers. RC vehicle guys soak tires in SG to make them softer and gripper.
DIY: plastic rear wheel skirts (Geo Metro) MetroMPG DIY / How-to 57 06-12-2014 09:16 AM
Done: A-B-A test on rear wheel skirts - Corolla, Camry Hybrid MetroMPG Aerodynamics 11 06-06-2009 03:49 PM
Rear wheel skirt / cover question pasadena_commut Aerodynamics 5 02-16-2009 04:50 AM
crx hf help need more info, rear wheel skirts RP-CLMBR Aerodynamics 2 07-16-2008 09:24 PM
Video: tuft testing rear wheel skirts - Geo Metro MetroMPG Aerodynamics 6 07-11-2008 08:26 AM
