Old 10-05-2013, 04:52 PM   #1 (permalink)
On board 12v Charging
Hi Guy's
My conversion to electric is about done, but here in the Uk I have a problem.
How do I charge the 12v system battery from the 144v DC batteries.
I tried a converted PC power supply but that can only output about 12.5v on a good day, my power steering pump takes about 10amps so the system 12v battery does not hold up very long.
When connected to the grid I use a switch mode 15.5v 10amp PSU (From China) but unfortunately it wont run on DC so I can not use that.
How do you guy's do it, is there a 150v DC to 12v/15v DC psu or charger out there.
Are there any chargers in the states that will run off 110/150v DC and charge at about 10 amps??
Old 10-05-2013, 06:48 PM   #2 (permalink)
Golfwagen - '89 Volkswagen Golf mk2
90 day: 107.14 mpg (US)
Hello.
Yes, there is a 150V to 12V device. It is called DC/DC converter. Most people use DC/DC converters in their conversions. I use this product: 400W DC-DC Converter Isolated/Non-isolated_Hangzhou Tiecheng Information Technology Co., Ltd. and 4x 90Ah LFP cells (12V accessory battery). I had a lead battery once but after it went down for the first time I replaced it with lithium.
There should be plenty of different products to choose from.
