Old 02-04-2018, 04:23 PM   #1031 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
BZP T-100 (2010) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 24 mpg (US)
BZP T-100 (2011) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 23.66 mpg (US)
BZP T-100 (2009) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (2012) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 25.45 mpg (US)
BZP T-100 (2013) - '98 Toyota T-100 SR5
Last 3: 25.79 mpg (US)
BZP T-100 (2014) - '98 Toyota T-100 SR5
Last 3: 23.18 mpg (US)
BZP T-100 (2015) - '98 Toyota T-100 SR5
Last 3: 23.85 mpg (US)
BZP T-100 (2016) - '98 Toyota T-100 SR5
Last 3: 17.62 mpg (US)
BZP T-100 (2017) - '98 Toyota T-100 SR5
90 day: 20.78 mpg (US)
BZP T-100 (2018) - '98 Toyota T-100 SR5
90 day: 20.19 mpg (US)
BZP T-100 (2019) - '98 Toyota T-100 SR5
BZP T-100 (2020) - '98 Toyota T-100 SR5
2012 Scion iQ - '12 Scion iQ Base
Send a message via ICQ to BamZipPow
Wink
You might want to make yer own thread so we can follow both iterations of single wheel trailers without thread jacking.
Might I suggest you take a peek over at singlewheel.com and see what technology already exists that you can borrow from.
Singlewheel trailers today
Keep yer goal in mind. Yer over building yer tail which won't be carrying anything because you want to reuse most of the parts from an existing trailer. You can take the same approach as the single wheel motorcycle trailers which already has an internal hub with high speed bearings and a rim/wheel combo that can take the load. The wheel is easy to remove and service. A simple swing arm suspension with an integral coilover spring/shock combo will be able to handle the road shocks without killing yer budget or yer unsprung weight.
Dark Aero-The world's first aerodynamic single wheel boat tail!
The Following User Says Thank You to BamZipPow For This Useful Post:
freebeard (02-04-2018)
Old 02-04-2018, 04:33 PM   #1032 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
Wink
Another example that you could borrow from.
Old 02-04-2018, 04:51 PM   #1033 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
Motorcycle wheels can be had fer cheap on craigslist.
https://houston.craigslist.org/mpo/d...461664055.html
https://houston.craigslist.org/mpo/d...443965998.html
Old 02-04-2018, 05:42 PM   #1034 (permalink)
My apologies. I didn't realize I was doing that. I guess since I'm looking at two wheels now, it doesn't belong in this thread.
The Following User Says Thank You to Angel And The Wolf For This Useful Post:
BamZipPow (02-04-2018)
Old 02-04-2018, 07:10 PM   #1035 (permalink)
Threads go in and out of focus. But OP rules, right? If you don't do a build thread, then a generic 'single wheel trailer' thread would be new. The Mods can split on off for you.
I'd contribute:
That last one would be a fiberglass rod geodesic 5-wheel Class-C motorhome. Or at least the start on one. I'm trying to get a 3D modelling work flow up and running again.
edit:
Ignore the triangles over the windshield and doors. Now that I think about it the whole motorhome body could pivot at the jack points just ahead of the rear wheels instead of flexing. Whee!
Sorry about the thread-jack.
What the headline giveth, the last paragraph taketh away. -- Scott Ott
Old 02-04-2018, 08:26 PM   #1036 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
Wink
Took me awhile to dig it out of my thread but this was one of the dual wheel setups I had found on the Internet. It would resolve the issue about suspension and dual wheels.
https://www.axlesandmorebyjoellc.com/
Old 02-04-2018, 09:43 PM   #1037 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
Wink
You can see the rear set of wheels are setup to be non-swivelling.
Old 02-04-2018, 11:35 PM   #1038 (permalink)
As a newbie, I have not found how to start a new thread, yet.
Old 02-05-2018, 01:12 AM   #1039 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
Wink
See the green button to the left that sez "New Thread"? Click it!
Old 02-05-2018, 02:33 AM   #1040 (permalink)
Done — like this:
http://ecomodder.com/forum/showthrea...tml#post560541
BamZipPow (02-05-2018)
