Old 12-12-2013, 10:56 AM   #71 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
BZP T-100 (2010) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 24 mpg (US)
BZP T-100 (2011) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 23.66 mpg (US)
BZP T-100 (2009) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (2012) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 25.45 mpg (US)
BZP T-100 (2013) - '98 Toyota T-100 SR5
Last 3: 25.79 mpg (US)
BZP T-100 (2014) - '98 Toyota T-100 SR5
Last 3: 23.18 mpg (US)
BZP T-100 (2015) - '98 Toyota T-100 SR5
Last 3: 23.85 mpg (US)
BZP T-100 (2016) - '98 Toyota T-100 SR5
Last 3: 17.62 mpg (US)
BZP T-100 (2017) - '98 Toyota T-100 SR5
90 day: 20.78 mpg (US)
BZP T-100 (2018) - '98 Toyota T-100 SR5
90 day: 20.19 mpg (US)
BZP T-100 current (2019) - '98 Toyota T-100 SR5
BZP T-100 (2020) - '98 Toyota T-100 SR5
Send a message via ICQ to BamZipPow
Wink
If you lose the top to the trailer, you'd gain a few inches in plan taper, but more in profile.
kach22i just posted this in the Wind Tunnel thread:
I will eventually lose the fiberglass tub completely when I build up the tail cone/boat tail up. I would still like fer it to have some functional storage space though. Fer now, I'll be working with the tub as I will need the space fer my upcoming road trip during Christmas.
Dark Aero-The world's first aerodynamic single wheel boat tail!
The Following User Says Thank You to BamZipPow For This Useful Post:
aerohead (12-12-2013)
Old 12-12-2013, 02:28 PM   #72 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
Bracket supports are mocked in place. Once I finalize their position, they will be bolted in place with T-nuts and ¼" bolts.
Gitting a feel fer the top piece...
A quick mock up of the sides...yes, it's my old aero cap Coroplast sides.
The Following 2 Users Say Thank You to BamZipPow For This Useful Post:
aerohead (12-12-2013), KamperBob (12-13-2013)
Old 12-12-2013, 03:03 PM   #73 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
And a quick mock up to the truck...
The gap between the front edge of the extended sides and the rear of the truck is 21". I plan to put in a pivoting 26" long gap cover attached to the truck bumper made from the clear polycarbonate roofing panel.
Old 12-12-2013, 03:29 PM   #74 (permalink)
3ea 9" U-shaped plates, like an Armadillo?
BamZipPow (12-12-2013)
Old 12-12-2013, 03:57 PM   #75 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
Wink
That would be pretty neat. I'm leaning towards a gull wing type of door on each side that would be attached to the aero cap. Flip it up to gain access...the air pressure should keep it from flipping up even though I'll have a mechanical fastener to keep it from moving on it's own.
Old 12-14-2013, 01:43 AM   #76 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
Wink
Pulled the cross beams off and painted them. Cut 2" off the front cross beam to allow fer the vertical 2x4 beams that will be bolted in place. I will probably tie them together across the bottom and extend the diffuser across it. The vertical beams will match the height of the aero cap top support rail and the bottom of the rear bumper...about 28.5".
The front brackets are now bolted through the trailer frame so they won't be going anywhere soon.
The extended sides will have a top and bottom. I've moved the wiring to the outside of the tub since there were too many issues with the wiring gitting damaged with luggage and cargo. The extended sides will keep the wiring discrete. I might even build up a fairing fer the single wheel using some pipe that will pivot at the front and slide open at the back to allow the wheel to pivot.
I'm considering building up the top of the extended sides and the tub lid with some Foamular and expanding foam covered with Tyvek as a skin. I'll have to see if I'll have enough time fer this one, too.
The side gap covers will be clear and will have 2 pivot points. I decided to move away from the original 1"x6" wood plank across the rear bumper setup and go with a simple metal strap setup. The bottom pivot point will be a bolt bolted through a metal strap which is clipped into place under the plastic bumper cover and secured from moving with another strap bolted to the bottom of the bumper. The top pivot point will be a mending plate screwed in place and a clevis pin passing through that and a support plate on the gap cover. This will allow me to easily remove the covers.
The top cover will be clear and be shaped to the rear of the aero cap. Metal straps will reinforce the shape front and rear. Metal plates will have to be secured to the top of the tub lid to keep the cover from wearing into the lid. The cover will be attached to the main rails of the aero cap hatch with the same securing pins to keep the hatch locked in place. I will have to test to see if the air flow will allow the cover to stay in place or not.
All the covers will be stored in the trailer when not in use. I finally had a key made fer the locking handle so I can lock it now.
I will update the dimensions of the trailer once I git it built up.
aerohead (12-14-2013)
Old 12-14-2013, 06:14 PM   #77 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
Wink
Had some time today to start the build up the front header/bulkhead and rear supports...
Bottom part of the front header/bulkhead...
Some 1x2 wood strips to help illustrate how the extended side panels will look like...
Now you can see why I'm thinking about building up the lid some...
A crazy idea with the lower transition...
Old 12-14-2013, 08:38 PM   #78 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
I think I will end up cutting that vertical bean down level with the 90° bracket and build up the area with Foamular. I'll probably split the difference in height with the horizontal gap cover and see how that goes.
Old 12-15-2013, 05:03 PM   #79 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
Since it was rather warm today (~65°F), I got the extended sides framed out...
Covered in Coroplast on the sides and Foamular on top (interior shot)...
A quick mock up to the truck...
Mock up of the clear Suntuf roof panel fer the top gap cover...
A quick mock up of the side gap cover...
I still have the bottom of the extended sides to trim, tape the gaps, and paint them flat black.
Still braining a good setup fer the gap covers.
Old 12-15-2013, 08:06 PM   #80 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
Dimensions of the trailer is now 60" wide at the front, 45" wide in the rear, and 62" long (front of the extended sides to the rear).
The T-100's rear comes in at 72". I have to recalculate the gap between the rear of the truck and the front of the trailer again.
I'm not too sure if I should trim up the Coroplast that over hangs the bottom edge of the trailer platform or not. What a dilemma...
Copyright ©2000 - 2021, vBulletin Solutions Inc.
