06-16-2022, 04:45 PM
#21 (permalink)
simple rear wheel fairings
Not sure if this will link. If it does, it's cedar, open cell polystyrene foam, brushed-on polyurethane barrier coating to protect foam from polyester-based filler, BONDO, primer ,paint, back-fastened wheel fairings behind SPIRIT's rear wheels, attached from the top down. https://ecomodder.com/forum/attachme...4&d=1249763104
Reason: correction
06-16-2022, 06:26 PM
#23 (permalink)
The attachment gets 'This ecomodder.com page can’t be found' at this time in this location.
#45
#47
#62
#107
06-30-2022, 03:57 PM
#24 (permalink)
Mechanical engineer
The Following User Says Thank You to Vekke For This Useful Post:
06-30-2022, 04:13 PM
#25 (permalink)
video
Thanks Vekke, that's probably as close as I'm likely to get to the car.
06-30-2022, 04:18 PM
#26 (permalink)
Mechanical engineer
I have once sat in at fair when it was launched and my head was hitting the roof if I moved even little. I am 193cm tall. I will try to ask for test drive and better place to take pictures. Today had toddler in my lap in harness so could not take any measurements of the car just rough estimate and few pictures.
06-30-2022, 05:16 PM
#27 (permalink)
I shall revise my suggestion from 2013. The U-shaped metal bracket becomes a[n Italic] V-.
The open end could evern be drifter stitched.
