Old 02-09-2010, 10:09 PM   #21 (permalink)
Just as has been said before if you're lugging the engine too much you'll know it by the way it responds to acceleration. Shuttering and vibration would be signs you're putting too much strain on the engine at low rpm's.
Old 02-10-2010, 12:35 PM   #22 (permalink)
Semi-serious ecomodder
ChillyBear's Avatar
Try using royal purple oil, It has a higher film strength which is great for protecting your valvetrain and your lower end. I use it because I lug mine around at 1k rpms from time to time.
Old 03-02-2010, 09:46 AM   #23 (permalink)
Calibration Engineer
Subie - '00 Subaru Impreza STi JDM
90 day: 22.49 mpg (US)
I've seen many premature problems with engines that have been badly lugged. Usually it's older people who don't seen to understand how to downshift when they want to speed up. I frequently see bad scouring on the piston skirts and resulting oil consumption.
Lugging is also not optimal from an efficiency/pollution point of view. High cylinder pressures and low RPMs mean a much higher chance of detonation. As a result carmakers tend to run a lot less timing in the 1500 heavy throttle range. A lot of them tend to richen up the mixture because that gives the engine a nice feel when you free rev it. This can be OK because it means if you stay in closed loop the car will learn a leaner fuel trim and run leaner than stoich for a few seconds after you return to normal driving - less so on newer cars.
If it sounds bad and feels bad it's usually bad. Lugging itself long-term will also tend to wear your rod bearings as it puts a lot of pressure on them for an extended period of time - and it's also the worst time to do it as at lower RPMs your engine has the lowest oil pressure. Some cars are much worse in this area than others.
Finally, fuel saving modes in your engine (such as EGR and lean running mode) won't come on at really low RPMs. For example a lot of the Mazdas and Mitsubishis the EGR won't activate until 1800-2000 RPM. (differs by engine/year/market)
-Michael
Restore oil additive... suspectnumber961 The Unicorn Corral 46 11-20-2018 12:15 AM
Article: Lean burn on an otherwise stock engine (testing Acura RSX K-Series engine) tjts1 EcoModding Central 4 01-07-2010 01:22 PM
Engine Insulation GdB EcoModding Central 5 11-30-2009 02:05 AM
Is it harm to race the cool engine ? chowpanchow Off-Topic Tech 5 06-25-2008 12:23 AM
