11-19-2013, 02:05 AM
#71 (permalink)
Originally Posted by euromodder
In the article that Neil linked to.
VW actually mfg some of these and there is a youtube vid ...
The composite brake rotors make a very odd sound like clay brick dragging
11-19-2013, 07:35 PM
#72 (permalink)
Too busy for gas stations
Turtle - '92 Honda Civic Vx Team Honda 90 day: 67.09 mpg (US) Rolla - '10 Toyota Corolla Le Beast - '91 Chevy V2500 Bus - '01 VW Eurovan MV Speed - '93 Harley bored and storked Harley w/ turbo/ nitrous 90 day: 53.09 mpg (US) Cal - '68 Ford Mustang GT/CS
A cost effective rim source would be space saver spare rims. Many now have 18x4, with a few currently only having 19's (mainly the higher end porsches etc). These can be had dirt cheap used, since there is currently nearly zero demand. I looked at a parallel situation for running MiEV tires.
Shooting for 600 miles of range at 65-70 mph out of a vx.
The Following 2 Users Say Thank You to Superfuelgero For This Useful Post:
12-15-2013, 05:10 AM
#73 (permalink)
There has been some discussion about the differences between 26 and 29 inch wheels and tyres on mountain bikes as the 29 inch size is fairly new. It seems that the shape of the contact patch is important to grip as well as its area
12-16-2013, 10:33 AM
#74 (permalink)
Will donut wheels hold up to every day use? I asked the question and was returned no.
12-16-2013, 11:26 AM
#75 (permalink)
Not banned yet
Blue - '03 Chevy S-10, LS
compact spares are not constructed for mileage. they are a temp measure. a tire built for 50-80,000 miles has a diff compound, ply pattern, bead material, etc...
2003 S-10, 2.2L, 5 speed, ext cab long bed.
So far: DRL delete, remove bed mount toolbox.
12-16-2013, 12:28 PM
#76 (permalink)
I think (?) the question was about the rim, to be used with the Bridgestone tire.
12-16-2013, 04:58 PM
#77 (permalink)
Not banned yet
oh.
12-17-2013, 07:11 AM
#78 (permalink)
Tire Geek
And the answer for the rim is the same as for the tire. The rim is built as a temporary measure. It is weaker than a normal wheel.
01-21-2014, 01:08 PM
#79 (permalink)
Here is the Bridgestone tires used on the BMW i3:
http://insideevs.com/bridgestone-rel...-bmw-i3-tires/
They have a regular and a snow version!
Ecopia EP500 ologic tire is available in four sizes:
155/70 R19 84Q
175/60 R19 86Q
155/60 R20 80Q
175/55 R20 85Q
I want the 155 70 19's!
01-21-2014, 02:01 PM
#80 (permalink)
maybe i missed it... why do they want large diameter wheels?
I have always assumed that tires were lighter than wheels, so always go with the smallest wheel for lower rotational inertia.
also larger sidewalls are much more comforatble that lo profile tires.
is this a LRR thing?
