Old 06-25-2008, 02:21 PM   #41 (permalink)
Wannabe Modder
Regarding using a standard but narrowed differential in the back: I thought of something similar but the Trike idea is such a good idea, and legally trikes are easy to register, and putting two wheels in the back would blow away the whole trike idea, plus increase rolling resistance.
I think the trike near the bottom of the first post in this thread is what a lot of us are talking about, just a little longer for a second rider:
http://ecomodder.com/forum/showthrea...80.html?t=1280
Old 06-25-2008, 03:28 PM   #42 (permalink)
Hi all
This is the idea , but I like my shape better [ looks wise ] but this is aerodynamically better :-
http://home.clara.net/peterfrost/tryaneii.html
he clearly has to much power if he can reach 100 mph on 602 cc !
regards paul
Old 06-25-2008, 04:48 PM   #43 (permalink)
[QUOTE=dcb;38238]That is like saying cars are not fuel efficient because hummers are not fuel efficient And 50mpg without trying is good![\QUOTE]
Depends on your standard of comparison. When you've been driving an Insight for the last 5 years, and averaging over 70 mpg (and that counts a lot of trips over 8500 ft mountain passes, some of them in snowstorms), 50 mpg does not seem good at all :-)
Less rubber on the road and smaller frontal area and a streamlined body (and a small engine) for our imaginary vehicle are a formula for mpg success.
Less rubber, yes, but that means 3 wheels instead of four. With just two, you have this annoying tendency to fall over when you hit snow or ice :-(
Old 06-25-2008, 05:23 PM   #44 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
With 3+ wheels you have this annoying tendency to be distracted by the cellphone and cheeseburger when you should be driving, regardless of the weather
Oh, and you scrub off a lot more mph in the corners, unless you have a fancy speed sensitive tilting mechanism. Plus that whole frontal area thing. So there's that whole they arent as efficient as two wheels thing
Old 06-25-2008, 05:31 PM   #45 (permalink)
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 Mercedes Benz 300SD
90 day: 23.23 mpg (US)
Gentoo320 - '04 Mercedes C320 4Matic
90 day: 22.44 mpg (US)
For maximum efficiency wouldn't one wheel be the best?
Monowheel - Wikipedia, the free encyclopedia
Old 06-25-2008, 05:47 PM   #46 (permalink)
Boxhead
whokilledthejams's Avatar
Boxy Brown - '04 Scion xB
90 day: 35.48 mpg (US)
Send a message via AIM to whokilledthejams
Originally Posted by 88CRX View Post
What I'd like as a feature in an ICE drive train, is the same mechanism in the back wheel of a bike, which allow the back wheel to spin freely, when you stop pedaling.
Then you don't have always go to neutral.
Older SAABs had a freewheeling feature, because they came with two-stroke engines (I forget precisely why, but you can't engine brake with a two-stroke). They even carried it over into some of the early four-stroke 96's.
As for those decrying the frontal area of a VW front beam: those cars are really, really small compared to anything modern. Of course, I can't find the track width of a VW Type 1, but I did find that Class 5-1600 Baja VWs are limited to a front track of 55.5". This is with modified desert-racing suspension. Stock is going to be several inches narrower-- I wouldn't be surprised to find that it's only 50" or so.
Desert Rides :: Racing Classes
For example, the front track of my xB is 57.3". That's substantially wider, despite being considered a subcompact vehicle.
The other distinct advantages of tadpole trikes lie in extremely stable handling, and potentially smaller frontal area than a car, because one could be made extremely low overall (think along the lines of a Porsche 550 Speedster with most of the rear end missing). Admittedly, it's a compromise between a car and a bike, but I feel a trike offers the best of both, despite the obvious aerodynamic limitations.
Old 06-25-2008, 05:55 PM   #47 (permalink)
ECO-Evolution
Lazarus's Avatar
Iron Horse (retired) - '97 Iron horse Intrepid
Ninja - '08 Kawasaki 250R
90 day: 76.23 mpg (US)
Here's a list of um.
"Judge a person by their questions rather than their answers."
Old 06-25-2008, 07:30 PM   #48 (permalink)
British Ecomod Hypermiler
AXMonster's Avatar
The AXe - SOLD - '97 Citroen Citroen AX 1.1i 5 Door
90 day: 46.78 mpg (US)
Foci - '03 Ford Ford Focus Tdci Ghia Estate
90 day: 64.37 mpg (US)
Originally Posted by Doofus McFancypants View Post
I have also dreamed about building one - three things are stoping me.
Time - Money - Space.
Steve
I've built one
Not quite the same as a Locost, as it has a 3.5 Litre (215Ci??) V8 LOL
1997 Citroen AX 1.1i SPI
2003 Ford Focus 1.8 Tdci estate
Ecomods: See my garage
Old 06-26-2008, 08:03 AM   #49 (permalink)
Eco Noob
Doofus McFancypants's Avatar
Red Rover - '01 Nissan Altima GXE
90 day: 30.07 mpg (US)
AXMonster.
That is sweet !!!
Did you build the frame yourself - or did you have made?
I'd wondered if there is enough room in the "trunk" for an electric motor and a FWD Transmission - then the "enginecompartment" can be full of batteries.
Steve
Steve - AKA Doofus McFancypants
"If there's a new way, I'll be the first in line - But it better work this time"
First Milestone passed - 30 MPG (city) 5/15/08
Best City Tank - 8/31/09- 34.3 MPG (EPA= 20)
Best Highway Tank - 5/20/09 - 36.5 MPG (EPA= 28)
In effort to drive less:
Miles NOT driven in 2009 = 648 (Work from home and Alt Transporatation)
Old 06-26-2008, 02:34 PM   #50 (permalink)
EcoModding Newbie
Parachute - '03 Chevrolet Tracker LX
90 day: 28.55 mpg (US)
Peon - '95 Plymouth Neon Highline baby!
90 day: 31.39 mpg (US)
Slocus Wagon - '06 Ford Focus SE
Originally Posted by AXMonster View Post
I've built one
So having built one car, would you build another? Just for mileage?
I am quite jealous of your diesel Focus, if I got that mileage then I don't think I'd bother building anything for fuel economy...
Now building a car like yours for fun, that could get me going in the garage(after I built a garage). Did you use a parts car for most of the suspension and drivetrain?
Ian
I found another advantage to driving an ultra-low Cd car basjoos Aerodynamics 26 08-25-2012 02:15 PM
EcoModding for Beginners: Getting great gas mileage. SVOboy EcoModding Central 55 08-20-2012 11:34 PM
Win $100.00 in Free Gas! Design Contest: Ecomod my Ride XFi EcoModding Central 127 02-17-2011 12:07 AM
My First Electric car Experience WaxyChicken The Lounge 8 09-05-2008 08:46 PM
$500 and 30mpg car? possible? olderthanme EcoModding Central 6 07-15-2008 09:37 PM
