Old 02-24-2012, 06:40 PM   #11 (permalink)
90 day: 40.51 mpg (US)
100%. It functions fine except that I don't know how to get back into the setup!
EDIT: left and right buttons at the same time fixed it, going to put it in its box now
Old 02-24-2012, 08:37 PM   #12 (permalink)
Complete! Pics in first post.
EDIT: I forgot the 220ohm resistor, but the brightness controls seem to work fine. Is that ok?
Old 02-25-2012, 06:43 AM   #13 (permalink)
meelis11's Avatar
Green frog - '97 Audi A4 Avant 1.9TDI 81kW
Diesel
90 day: 43.1 mpg (US)
resistor limits maximum current to display backlight. If you set it to maximum brightness then it maybe overheats...but when using dimmer backlight, then you probably dont have a problem.
Old 02-25-2012, 07:26 AM   #14 (permalink)
Resistor limits current from arduino to backlight controlling transistor. If it’s not installed it might overload arduinos processor and baclight controlling transistor. Overloading can happen regardless of backlight brightnes as long as its on and can result in damaging both the transistor and processor. So install the resistor before you use it.
Old 02-25-2012, 11:46 AM   #15 (permalink)
Thanks, I pulled it apart and did so!
