Old 02-01-2023, 06:31 PM   #1241 (permalink)
mpg_numbers_guy's Avatar
Toby - '13 Toyota Prius C
90 day: 63.99 mpg (US)
Daz - '15 Mazda 3 iTouring w/ Tech Package
Team Mazda
90 day: 38.2 mpg (US)
$25 trailer rental for the day. Still averaged 33mpg with 5 hours of towing.
There are trailers for rent here literally 5 minutes from any home, and they're always available.
How does your Miata do with towing versus your Insight?
2013 Toyota Prius C 2 (my car)
2015 Mazda 3 iTouring Hatchback w/ Tech Package (wife's car)
Old 02-01-2023, 06:54 PM   #1242 (permalink)
90 day: 84.25 mpg (US)
The Insight post-swap with 1000lbs behind it, could out-accelerate most empty pickup trucks with an empty bed. That was good for laughs. I also towed at 80mph with a 50mph headwind, and the larger engine did this effortlessly. The Miata's 1.5L engine is plenty for New Zealand's lower speed limits though (national limit of 100kph, and you should do 90 or less when towing), and I was even able to stay in 6th gear going up mild inclines.
I don't know how heavy the trailer was, but braking downhill at higher speeds, it wanted to wag the back of the car. This disappeared dropping below ~90kph, and other than that I could hardly tell it was back there. With the Insight, I always used a custom lightweight aluminum trailer that was carefully loaded and never experienced this, even though the back of the car was much lighter. I don't have an apples-to-apples comparison. Both straighten out when you get on the power, though.
The Insight with a 2.4L delivered better towing fuel economy than the Miat with its high compression 1.5L, though not by much.
The Miat has better brakes - they're really quite oversized for the car. The Insight pre-swap had 231mm front discs and aluminum rear drums. Post-swap I had 262mm front discs from the 2800lb Civic Si up front, while the car itself was ~2000lbs with a full tank and tools in the back. The Miat has 280mm discs front and rear and is under 2200lbs.
Prior to the engine swap, the Insight's 3 cylinder took a while to get up to speed, but I never had a problem towing, even with the hybrid system removed.
I would say that both cars are effortlessly competent at towing 1000lbs or less. I've towed twice that in the Insight, poorly loaded, and it was quite nervous. The Miat can probably safely tow more, by virtue of a stronger mounting point on the frame (steel, on the rear frame rails), from the rear of the car being heavier, and bigger brakes.
I'd probably still pick the Insight for towing, however, by virtue of better fuel economy, larger hatch (probably 6x the storage), better acceleration, and the Miat not being able to be playful while towing. I did, however, have the top down the entire time, and got a lot of thumbs-ups.
Old 02-02-2023, 07:12 PM   #1243 (permalink)
Originally Posted by dremd View Post
Ok, what mid 90’s wagon is that? I’m not recognizing it, maybe a Mazda?
That's a Volkswagen Parati of the 2nd generation. That's what the US-spec Fox would've been turned into if it hadn't been phased out earlier.
Old 02-03-2023, 10:38 AM   #1244 (permalink)
This is not the way.
Old 02-03-2023, 11:56 AM   #1245 (permalink)
90 day: 33.31 mpg (US)
90 day: 62.22 mpg (US)
LOL, and now the gate probably doesn't open, either.
Dad backed into the pole of the machine shed with the gate down on my truck. Just added more "character".
Old 02-03-2023, 04:23 PM   #1246 (permalink)
Beef Supreme - '23 Kia EV6 GT
That is why I went big with my trailer at 5' x 10'. I don't use it much and 5 years later could have saved significant money by renting, but the last thing I want to worry about is whether what I want to haul will fit!
2023 Kia EV6 GT
Old 02-04-2023, 01:15 AM   #1247 (permalink)
Weren't those retractible bed extenders meant to deal with those longer loads?
Old 02-04-2023, 01:58 AM   #1248 (permalink)
That's why men don't buy a short-bed.
Ecky (02-04-2023)
Old 02-04-2023, 02:27 AM   #1249 (permalink)
I recall chains with a rubber sleeve over them.
Loos like someone didn't slow down for the railroad tracks.
The older I get, the better I was -- John Fogerty on Joe Rogan
Old 02-04-2023, 04:55 AM   #1250 (permalink)
I saw this recently:
pickup, trailer
