Old 11-24-2009, 12:18 PM   #1 (permalink)
Golf SE 2.0 TDI 140PS 6 Spd
Hiya, just got a new VW Golf SE 2.0 TDI 140PS 6 Spd & would like to know how to get the best fuel economy out of it while looking after the engine, the torque band is 236@1750-250! Should I be trying to keep in the torque band as much as possible? Currently running at 56mph at around 1700-1750 on the motorway! Ta for any help!
Old 11-24-2009, 01:43 PM   #2 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
Diesels: keep 'em below 2000 rpm.
And a grille block, since diesels take a while to warm up.
Old 11-24-2009, 02:19 PM   #3 (permalink)
90 day: 51.82 mpg (US)
Does the new Golf have onboard, resettable fuel consumption display? Using that, and religiously logging every fill up is the foundation of figuring out how you're doing and whether you're improving or not.
I imagine you'd be getting really good fuel economy at moderate speeds like that.
Old 11-24-2009, 04:27 PM   #4 (permalink)
Chug - '96 Volkswagon Polo CL
90 day: 49.42 mpg (US)
L'Autre - '03 Renault Megane Sport Tourer Expression
Diesel
90 day: 45.02 mpg (US)
Hi Mate - I'm just down the road from you (warrington) what kind of mpg are you getting at the moment??
good things come to those who wait, sh*t turns up pretty much instantly
twitter.com/bertchalmers
Old 11-25-2009, 06:31 PM   #5 (permalink)
Hiya thanks for the advice, yep the Golf has a fuel consumption display, think I'm averaging just under 52mpg, small world Rob yep I'm just up the road from ya!
Old 11-25-2009, 06:37 PM   #6 (permalink)
White 4Runner - '98 Toyota 4Runner SR5
90 day: 23.21 mpg (US)
Grey Jetta TDI - '11 VW Jetta
90 day: 39.17 mpg (US)
Did you get the 2 door or 4 door?
Old 11-26-2009, 04:41 AM   #7 (permalink)
Diesel
You may find that cruising at 68-72 may yeild better results - I know that sounds counter productive but you should only have to to use the weight of your foot to sustain it. Most modern dubs are set-up to cruise at 130kph, the legal limit in most european countries and the rain/junction limit im Deutscheland.
do you mainly drive on motorways or backroads? as from experience with bruv's 140tdi they are great a-to-b cars on minor roads
Old 11-26-2009, 02:59 PM   #8 (permalink)
I’ll try cruising at 68-72 in 6th gear thanks; I’ve been running at 56mph in 5th gear! I use mostly motorways, travelling to work down in Northwhich, if I think the motorways gona be busy I’ll use the A roads!
Old 11-26-2009, 03:01 PM   #9 (permalink)
Got the 2 door!
Old 11-27-2009, 08:41 AM   #10 (permalink)
Diesel
I do warrington-crewe, must have been stuck in th odd traffic jam together!! I do M62-6-then off at J18
Installing MPGino in 2002 Golf TDI dremd OpenGauge / MPGuino FE computer 55 09-28-2012 06:59 AM
News: VW to unveil 70 mpg (US) Golf diesel hybrid MetroMPG Hybrids 27 06-29-2010 07:50 AM
2003 Golf TDI Tires? Lostyankee EcoModding Central 6 09-18-2009 10:22 AM
[FS] 1987 Ford Escort 2.0 DIESEL Drivetrain 5spd Trans SE PA + EXP Project Car XFi For Sale 0 09-30-2008 02:37 PM
VW Golf 2.0? TheDon General Efficiency Discussion 4 06-20-2008 02:56 PM
