Old 08-12-2009, 12:41 PM   #1 (permalink)
Engineering first
bwilson4web's Avatar
17 i3-REx - '14 BMW i3-REx
Last 3: 45.67 mpg (US)
Blue Bob's - '19 Tesla Std Rng Plus
Calibrating the 2010 Power Bar (ECO mode)
Hi,
Last night was too overcast to watch the meteor show so I took a couple of runs up Brindley Mountain with our Garmin GPS to get more hybrid system indicator (HSI) energy display data. In particular, I wanted to check the 75% and 100%, Eco band points:
NOTE: the clear cover causes a parallax error from the 8", cell phone camera. From the driver's head position, the yellow electrician tape markers look right.
I ran two climbs holding either 100% of the Eco bar or 75% and got these results:
The 100% Eco mode, 23.4 hp, came pretty close to my earlier, flat-land acceleration test. The 75% level was off, 15.3 vs. 12.8 hp, but I knew my earlier acceleration tests were somewhat dependent upon a few samples over a short interval. I have good confidence in the 15.3 value.
I have the data in a spreadsheet if there is any interest in seeing how I did
it.
Because this was a new procedure, I failed to record the fuel consumption rate. I'll have to go back and repeat it. However, at 100% of Eco bar, the car went up at an average of 35 mph (56 kph) but only 25 mph (40 kph) at 75%. The posted speed limit is 65 mph (104 kph) so it needs to be done when there is little traffic about and with the safety blinkers flashing. I am very uneasy about trying 50%, Eco bar power.
Bob Wilson
2019 Tesla Model 3 Std. Range Plus - 215 mi EV
2017 BMW i3-REx - 106 mi EV, 88 mi mid-grade
Retired engineer, Huntsville, AL
Old 08-14-2009, 11:44 PM   #2 (permalink)
Engineering first
I was able to go back and this time record mileage. At 2:00 AM, I was able to run a 50% power run too:
power miles MPG mph
100% 1.5 23.8 35
_75% 1.5 25.3 26
_50% 1.5 22.2 16
On the descents, I simply put the car in "B" and let gravity and the spinning engine do the rest. But I noticed the battery fully charged and the top bar, slightly pink, was illuminated.
I returned to my starting point, about a mile away from the base of the hill and the battery was still fully charged. On the second run, the battery charge still showed full as I approached the base of the hill. I suspect this is why the middle run showed exceptionally high mileage, a battery boost.
For the last run, I used "EV" mode to bring the battery out of the 'pink bar,' full charge and then used regular "D" to approach the hill. Until there is a standard way to normalize the battery charge, I won't be able to trust this data.
To handle the battery energy contribution, we need to measure the traction battery current. Then comes the challenge of trying to use the charge/discharge energy flow to compensate for the altitude and distance.
Bob Wilson
Why We Have No Wind or Solar Power SuperTrooper General Efficiency Discussion 220 07-20-2011 10:37 PM
Gen III 2010 Prius Matt Herring Hybrids 3 08-30-2010 03:04 AM
2010 Prius unveiled: Cd 0.25, 50 mpg EPA combined, EV mode MetroMPG Hybrids 56 07-26-2009 03:48 PM
Diesel Power Magazine Disappointment. ConnClark EcoModding Central 16 06-05-2009 10:39 PM
