Road Test #112 main jets, #35 slow jets
112KM @/or above posted speed limits 80% @115km/h, 15% @100km/h
3.0L
2.68L/100km, 88mpg
ambiant air temp 15*C
some cross wind
The air/fuel guage readings were 14.0 under light load +/- 0.5 @ 110km/h+ [70mph+]
12.0 under acceleration +/- 0.5
16.5 with throatle closed +/- 0.5
I think I will try the #108 main jets next to see if they work well enough. If not then I can go back to the #110 main jets.
It seems like it has a built in lean burn?
The coolent temp is still a bit high for my liking, even though it is in the normal range?!
