Old 10-06-2009, 06:05 PM   #21 (permalink)
mwebb's Avatar
no nickname , it's just a car - '04 volkswagen golf tdi
"Sorry but there is such a gauge, a Vaccum Gauge...
Rich
yes of course ,
however
the vacuum gauge has already been invented and in order to use it in the car , you need to run a vacuum line and mount the gauge somewhere ,
but a simple wire from the "load sensor" to a small high impedance voltmeter either analogue or digital samples the signal with the most authority that the ECM / PCM uses for calculating how much fuel to add at almost any given time ,
not counting decel fuel cutoff or clear flood or open loop WOT fuel enrichment conditions ,
better still, but much less simple ;
to just use the calculated load PID in scan data .....
lower is better for fuel economy ....
but most people will not want to have a laptop on the passenger seat as they do most of their driving , and it is awkward and distracting to look to the right seat all the time ...
Old 10-06-2009, 06:17 PM   #22 (permalink)
Typos will be the death of me...
True BUT a vacuum guage does a great job, it shows when you add a little throttle (lower vacuum...) and when you step off (higher) and it can also do some checking and warning of problems in the engine as well...so for a little cost and a lot less work of hanging that meter and hooking up to something and trying to figure out is more voltage a good thing or a bad the vacuum gauge is butt simple low vacuum low mileage...
And there are those great looking piller pods for mouning it and it can look cool.
I have had one in every car I have owner from my 56 Studebaker on....(it was stock in the Stude
Rich
Diesel- and Hybrid-Powered Vehicles Can Provide More Societal Benefits than Gas-Power SVOboy General Efficiency Discussion 12 04-29-2017 08:03 AM
Recovery rate of end-of-life vehicles blueflame EcoModding Central 1 02-09-2009 09:31 AM
Tested vehicles in the garage steensn Forum News & Feedback 1 07-11-2008 03:48 PM
Top Five available eco-mod vehicles?? offroad1994 EcoModding Central 27 07-08-2008 04:46 AM
If all the vehicles on the road were ultra-low Cd.... basjoos EcoModding Central 10 01-07-2008 08:34 PM
