Old 05-21-2012, 07:19 PM   #1 (permalink)
Infiniti - '11 Infiniti G25X AWD
90 day: 29.82 mpg (US)
Can restricting airflow actually increase mpg
Just had a couple thoughts and am looking for some answers that i am not sure of. If getting more airflow into the intake will increase HP, would restricting airflow decrease the HP of the engine, thus using less fuel to keep the mixture correct? I know the thinking is more HP allows you to keep out of the throttle, but would less hp make your engine act like a smaller engine? The other side of this would less airflow make it run less efficient?
Old 05-21-2012, 07:22 PM   #2 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
the simple answer is no.
There have been studies with completely clogged airfilters and the performance is the same as a new filter.
but one of the more 'phD eco-modders' will chime in.
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
Old 05-21-2012, 07:29 PM   #3 (permalink)
tortoise's Avatar
number 9 - '89 Geo Metro LSi
90 day: 49.25 mpg (US)
Closing the throttle (letting off the gas pedal) will restrict airflow and use less fuel. Also, you'll go slower.
Old 05-21-2012, 08:33 PM   #4 (permalink)
GRU
GRU's Avatar
silver bullet - '00 Honda Civic
90 day: 34.41 mpg (US)
the only way it would help to restrict the engine is if the driver is the type that drives and acceleartes too fast (using up too much fuel) so if you restrict the engine it would force the driver to drive slower.
Old 05-21-2012, 08:34 PM   #5 (permalink)
tortoise's Avatar
I kinda think maybe a completely clogged airfilter would give no performance. (But then, I don't have a phD.)
Old 05-21-2012, 10:06 PM   #6 (permalink)
mcrews's Avatar
yeah, probably a bad choice of word.
ECO MODS PERFORMED:
First: ScangaugeII
Old 05-21-2012, 10:32 PM   #7 (permalink)
Volt, gas only - '12 Chevrolet Volt Premium
90 day: 38.02 mpg (US)
Volt, electric only - '12 Chevrolet Volt Premium
90 day: 132.26 mpg (US)
Yukon Denali Hybrid - '12 GMC Yukon Denali Hybrid
90 day: 21.48 mpg (US)
on modern fuel injection systems, air filters don't directly affect mileage. the engine will keep the mixture at the programmed ratio regardless of the filter, but a clogged filter will decrease power thus forcing the driver to push the pedal harder to get the same power.
air filter relates to performance and fuel economy is a side effect.
Old 05-21-2012, 11:09 PM   #8 (permalink)
...beats walking...
phD = "piled higher & Deeper"
The Following User Says Thank You to gone-ot For This Useful Post:
Christ (05-22-2012)
Old 05-21-2012, 11:41 PM   #9 (permalink)
it takes X horsepower to go a certain speed, or accelerate at a certain rate.
If the air filter is clean and flowing well, the restirction is the throttle, which uses horsepower. If the air filter is mostly plugged, and a huge restriction, then the restriction is the filter AND the throttle, which takes the EXACT same amount of horsepower.
Old 05-21-2012, 11:45 PM   #10 (permalink)
mwebb's Avatar
no nickname , it's just a car - '04 volkswagen golf tdi
maybe
not by restricting flow
but
possibly by taking the incoming air charge from an area of lower pressure,
like from behind a tire or from behind the car
the difference in pressure would be so small , the gains if any would be difficult to measure .
restricting flow can reduce maximum available power output but can not change FE Unless the system is carburated
2x as per the EPA (which never lies or fibs) and IATn which is more accurate and subject to a demand / need to prove test results .
