Old 09-10-2009, 02:55 PM   #21 (permalink)
The XT - '92 Yamaha XT225 Serow
Last 3: 80.67 mpg (US)
White Civic - '08 Honda Civic Hybrid
90 day: 38.23 mpg (US)
Blue and White Beast - '78 Ford F150
90 day: 11.33 mpg (US)
Red T100 - '93 Toyota T100
90 day: 14.7 mpg (US)
Originally Posted by Christ View Post
Oh, another thing that's been brought to my attention a few times:
Another aeromod that is often overlooked that doesn't affect cooling in any negative way is to shroud the radiator completely, so that all the air that does hit the radiator has to go through it, rather than around it, into the engine bay.
This creates sort of a parachute effect, but the excess air has nowhere to go, so instead of going around the radiator, like it normally would, it creates a (insert proper term here) that blocks further airflow until the air that's already being pressurized in the grille/radiator area is through the fins of the radiator.
In other words, it builds pressure there, so excess air is forced around the grille, rather than allowed through it.
Wouldn't that be most effective if you used to block more grill so because the air that gets through is more effective?
Also, as far as improvements, I showed a 6% improvement on my Jeep with an A-B-A test. This is probably more than I'll get in the real world, I'd prefer more test runs, but I only have so much time to run tests. When I put it back on soon, I'll see if it has a noticeable effect in daily driving. BTW, no overheating and I believe Wranglers are known for this problem.
Old 09-10-2009, 02:56 PM   #22 (permalink)
Oh and as far as temperature gauges, if you have an SG it should be able to show water temp. I used that while testing my grill block.
Old 09-27-2009, 03:02 PM   #23 (permalink)
OCD Master EcoModder
brucepick's Avatar
Outasight - '00 Honda Insight
Gen-1 Insights
90 day: 54.18 mpg (US)
RandomFact314, I think by this point you've maybe got this information sorted out, but from your first posts here it looked like some clarification might be in order. Sorry that a lot of what's below is sorta off topic but - if you're going to discuss modifications to the cooling system these basics need to be in your head first. In my humble opinion, of course.
The radiator is passive. Water (coolant) goes through it and and air passes over the fins, which cools the water. If there's absolutely no air flow (or no water flow), the water isn't cooled. Exactly how much cooling occurs depends mostly on air temperature and air flow speed.
The thermostat is also passive. In fact it's mechanical. When t'stat is cold it is fully closed, and water circulates through the engine and pump in a loop. Water flows through it and when it reaches a set temp the t'stat valve opens slightly, allowing some water to flow to the radiator. As the water gets warmer the t'stat gradually opens up further allowing more % flow to the radiator till it reaches a temp (maybe around 200-205 deg. F) where it's allowing full flow to the radiator, as much as it can open up the valve. Boiling is 212 deg. F so it's fully open before that point. Also, the cooling system is sealed so the boiling point is actually a bit higher than 212.
Under most conditions the t'stat and road speed airflow over the radiator are enough to keep the engine from getting too hot. Lengthy idling, heavy stop and go driving, or brutally hot days with a/c combined with idling or stop+go, can can set up conditions where the engine isn't sufficiently cooled. Enter the radiator fan. The fan increases air flow over the radiator fins so as long as everything else is in good working order, this will increase cooling capacity.
Assuming a 'modern' computer controlled car, the 'puter monitors the coolant temp and will start the (electric) radiator fan if coolant temp rises to some set limit. In my car it seems to kick in around 206 deg. F, which I can track on the ScanGauge.
Earlier cars, especially rear drive cars with in-line engines, had a mechanical fan run off engine belt pulleys, located right behind the radiator. Instead of computer controlled switching, it had a mechanical thermostat that increased the speed of the fan when the coolant got too hot. Otherwise the fan was nearly freewheeling; with the engine off you could spin it by hand.
Coast long and prosper.
Old 09-28-2009, 01:08 AM   #24 (permalink)
rusty - '00 ford mustang coupe
90 day: 24.31 mpg (US)
cbr929 - '00 honda cbr929 fast
90 day: 39.54 mpg (US)
Porshe - '06 Kawasaki zx10r
90 day: 47.21 mpg (US)
truck - '96 ford ranger
90 day: 26.51 mpg (US)
The mpg gains are going to depend on where you drive, how you drive, what kind of car you drive, and how much air that you block. Let me explain.
if you only drive on the highway, you can block the whole grill and you'll get the best results, reason is, less air drag, faster warm up. now if you drive in the city in stop and go traffic less than 25mph, you won't get much, and will probably loose gas mileage, the reason is, grill block doesn't give you any advantage aerodynamic wise cause you're not going fast enough, and second there isn't enough air going through your radiator so your electric fan will run so much more using energy to keep the car from over heating.
block, grill, radiator, thermostat
Permanent Aluminum Grill Block and Belly Pan Markmysite EcoModding Central 41 02-27-2014 09:22 PM
additional cooling to accommodate full grill blocks Daox EcoModding Central 12 06-20-2009 12:48 PM
Molding grill blocks skyl4rk EcoModding Central 1 04-13-2009 10:24 AM
screen for grill blocks Bakerboy Aerodynamics 1 07-25-2008 02:12 AM
pressure sensors for testing grill blocks? pasadena_commut Aerodynamics 15 07-10-2008 11:34 PM
